Page 5 of 91 FirstFirst ... 3456715 ... LastLast
  1. Posts : 72,052
       #40
    Hello Colin, and welcome to Seven Forums.
    What happens when you click on the download link of the file extension? Do you get the pop-up windows to click on Save? You might look to see if it may just be hidden behind another open window.
  2. Posts : 7
    windows 7 home edition
       #41
    No, it says I do not have the permissions to download the file.I think my Perms need fixed:P
    Edit:thanks for the welcome Loving this website
  3. Posts : 72,052
       #42
    Colin,
    Are you logged in to a standard account that is restricted by Parental Controls instead of an administrator account?
    You might also check your installed antivirus or other security programs to see if they may be blocking you from being able to. Test by temporarily disabling them.
  4. Posts : 7
       #43
    Nooo:P Its a Vbulletin Permission Error
  5. Posts : 72,052
       #44
    Try logging out, deleting the website's cookies (you can use CCleaner to), then log back in to see if you can afterwards.
  6. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #45
    I don't have any problems here. Are you able to download files from other sites? What does the error actually say?
  7. Posts : 7
       #46
    Oh i just found out, it allows me to download everyother one except .ico one
    Could you give me it some other way? like pm or uppit.com etc
    thanks
  8. Posts : 72,052
       #47
    Collin,
    Here it is for ICO in both a ZIP or REG file download. Hopefully one will work for you.
    Default File Type Associations - Restore Attached Files
  9. Posts : 7
       #48
    Thanks for that
  10. Posts : 72,052
       #49
    You're most welcome. :)
