Page 12 of 91 FirstFirst ... 2101112131422 ... LastLast
  1. Posts : 71,977
       #110
    Hello Lacsong,
    PSD has been added to the list. :)
  2. Posts : 60
    Windows 7 Ultimate x64/Windows 8 Enterprise
       #111
    But it still dosen't show up
    Ok. I put your reg entry in but still zip didn't show up. I know where the file extentions are put in the registry. They are under hkey_classes_root.Could you give me the instructions on how to do this manually in the registry.
  3. Posts : 71,977
       #112
    Hello Shelbourne,
    Could you give some more details on what problems you are having with ZIP files? This will help better determine what may have happened and how to possible fix it for you. :)
  4. Posts : 60
       #113
    Brink,
    My default program for ZIP was extractnow, but somehow it got set to windows explorer. Then the .zip entry in set associations disapeared, and it was .zfsendtotarget. Then, i set the .zfsendtotarget to ExtractNow and it disappeared completly. I know where it is in registry, so could you give me instructions on how to manually edit the registry. Windows explorer does not extract very well:)
  5. Posts : 71,977
       #114
    Shelbourne,
    Since you are wanting Extractnow as you default program for ZIP files, you might see if clicking on Settings in Extractnow, click on Explorer tab, than select (check) zip, then click on Apply will set ZIP files to open with Extractnow. Also check the "context menu" items you wanted as well.
  6. Posts : 60
       #115
    Brink,
    I altered the registry last night with settings simalar to the extentions that worked with extractnow. I put those into the zip, but my laptop didnt want to boot up, so i couldnt test it until tonight. Now the extractnow settings were on zip, but it was the registry that was the problem. :)
    Attached Thumbnails Attached Thumbnails Default File Type Associations - Restore-work.jpg   Default File Type Associations - Restore-capture.jpg
  7. Posts : 71,977
       #116
    I'm happy to hear that you got it sorted. Thank you for posting back with your results. :)
  8. Posts : 1
    windows 7
       #117
    pdf needed
    I need to restore the default for a pdf! Somehow win7 got mine screwed up! I have been unable to associate the file type with adobe and unable to click the check box to "set as default"
  9. Posts : 71,977
       #118
    Hello Renee, and welcome to Seven Forums.
    PDF has been added to the list. It will remove all associations for the .pdf file extension in Windows 7 since this it the default in Windows 7.
    You might see if uninstalling Adobe Reader, then either reinstalling Adobe Reader or Foxit Reader may help reassociate pdf files to one of them.
  10. Posts : 1
    windows
       #119
    masterr2
    thank you men
