#160
Rich,
I'm not sure how this is suppose to work. I do not see any command or REG files when I edit the BAT or LST files that will make any changes in the registry.
Rich,
Ah, communications problem. All I created is a small batch file and list files to create the 5 zip file sets. I was not thinking of actually applying them en mass. Interesting thought though. Maybe a VB Script to provide a list from which you can choose one or more to apply. That sounds like fun .... off to think about it.
PS: I also just updated the zip file.
I need a .dat fix for the default file type assocation. Can you post one here?
Hello 3bikes, and welcome to Seven Forums.
Most certainly. One dat file download added. :)
Hi Brink, when I try and merge the reg file for .exe and .zip I get The specified file is not a registry script. You can only import binary registry files from within the registry editor. My big problem is I can't execute an .exe file, it gives me a not a vaild win32 application, then when I try and merge the reg to hopefully fix, I get the above error, any ideas?
Hello Davey, and welcome to Seven Forums.
You might see if you may be able to do a system restore at boot, with your Vista installation DVD, using a restore point dated before this happened may be able to fix it for you.
Brink, I don't have a system restore point, though D: is a system recovery, I bought the laptop at walmart in North Carolina, plus would a system restore point and/or a system recovery delete files? is there no way around this
Windows 7 by the way
Are batch (.bat) files affected? If not, I might be able to convert the files for you. It will probably be tomorrow or possibly Sunday before I can get round to it though.
not sure if my bat files are effected, but I can wait out the time
