Eject and Close CD/DVD Tray - Add to Desktop Context Menu
Page 1 of 9 123 ... LastLast
    How to Add "Eject/Close CD/DVD Tray" to the Context Menu in Windows
    This tutorial will show you how to add Eject/Close CD/DVD Tray to the folder background, drive, and desktop context menu, and file/folder context menu in Vista, Windows 7, and Windows 8.
    When used by a user, it will toggle the default CD/DVD drive's tray to eject (open) or close.
    You must be logged in as an administrator to be able to add this to the desktop context menu, but all users on the computer will be able to use it after it has been added.
    If you need this to work for a specific CD/DVD drive letter instead, then please post and let me know. I'll be happy to modify the .bat and .reg files below for the drive letter you wanted instead. :)
    EXAMPLE: "Eject/Close CD/DVD Tray" added to Desktop Context Menu
    Eject and Close CD/DVD Tray - Add to Desktop Context Menu-example.jpg
    Here's How:
    1. Do either step 2 or 3 below for what you would like to do.
    2. To Add "Eject/Close CD/DVD Tray" to Context Menu
    A) Download the 32-bit or 64-bit version of NirCmd that is the same as your 32-bit or 64-bit Windows at the bottom of the website below, and save the ZIP file to your desktop.
    B) Open the downloaded ZIP file, and extract (drag and drop) the nircmd.exe file to your desktop, and unblock the file.
    C) Click/tap on the Download button below to download the .bat file below, and save the .bat to your desktop.
    Eject-Close_CD-DVD.bat
    Download
    D) Unblock the .bat file.
    E) Move both the unblocked nircmd.exe file and unblocked Eject-Close_CD-DVD.bat file into your C:\Windows\System32 folder, and approve (Continue-Yes).
    NOTE: The bat file must be named this exactly. Rename if needed.
    F) Click on the Download button below to download the .reg file below, and save the .reg file to your desktop.
    Add_Eject-Close_CD-DVD_Tray_to_Context_Menu.reg
    Download
    G) Double click/tap on the REG file to merge it, then click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK when prompted to approve the merge.
    3. To Remove "Eject/Close CD/DVD Tray" from Context Menu
    A) Click/tap on the Download button below to download the file below.
    Remove_Eject-Close_CD-DVD_Tray_from_Context_Menu.reg
    Download
    B) In Windows Explorer, navigate to C:\Windows\System32, and delete the nircmd.exe and Eject-Close_CD-DVD.bat files.
  1. Posts : 25
    Win7 Home Premium 64 bit
    Love It
    Getting to the "Open/Close" tray button is an awkward manoeuvre in my set up, but dropping in the disc is easy enough, so this is great, thanks for the work.
  2. Posts : 72,058
    You're welcome dohouch, and welcome to Seven Forums. :)
  3. Posts : 23
    Win 7 Home Prem 64
    Brink...you've helped me before, so I had faith to try this. This is about the 4th "close tray" app I've tried, none work, incl this one. Using Win7/64 Home Prem, 2 LG CD/DVD reader/burners.
    Everything seemed to go smoothly. D/L Nircmd-64.zip, came with 3 files, I pulled out nircmd.exe. Put it and .bat (both unlocked) in Sys32. Ran the REG file, did a restart.
    But nothing added to context menu. Zip! I'm beginning to suspect the LGs, that's the only common thread to the all these "close tray" apps that don't work.
    Any ideas?
  4. Posts : 72,058
    Hello Chris,
    The REG file is what adds Eject/Close CD/DVD Tray to the context menu of the desktop. When you right click on the desktop and click on Eject/Close CD/DVD Tray, it runs the BAT file that has a command that runs using the nircmd.exe file.
    What happens when you merge the REG file? Are you getting prompted to click on Run, Yes (UAC-Windows 7), Yes, and OK after merging it? You might also see if right clicking on the REG file and clicking on Merge will work to see if there may be a issue with your reg file associations.
  5. Posts : 23
    Win 7 Home Prem 64
    Brink......whoops, my bad. The entry is on the DESKTOP context menu, not the drive's context menu! So it works.
    I have two CD/DVD trays. The entry appears to be controlling my D: drive correctly. Drive E: is apparently not being controlled at all, but I can live with that. Thnx.
  6. Posts : 72,058
    Ok. That's great news then. Yeah, it will only open/close the default CD/DVD drive.
  7. Posts : 96
    can u make it so that the context menu shows
    close tray directly underneath eject
    It makes it easier to find eject and close since they are close to one another
  8. Posts : 72,058
    Hello madmax,
    The context menu item in this tutorial is basically just a toggle switch to open/close the default CD/DVD drive.
  9. Posts : 96
    Brink said:
    Hello madmax,
    Can you post an image of how the context menu should look like in the windows 7
