Eject and Close CD/DVD Tray - Add to Desktop Context Menu
Page 2 of 9 FirstFirst 1234 ... LastLast
  1. Posts : 72,051
    madmax2 said:
    Brink said:
    Hello madmax,
    The context menu item in this tutorial is basically just a toggle switch to open/close the default CD/DVD drive.
    Can you post an image of how the context menu should look like in the windows 7
    It's the example screenshot at the top of the tutorial for only when you right click on the desktop.
  2. Posts : 14
    win7 Ultimate 64
    Thanks Brink sure beats the push tray!
  3. Posts : 72,051
       #12
    You're most welcome Korea7. That was my main motivation for posting this tutorial.
  4. Posts : 96
    Hi
    I did what was shown in the instructions but I don't get the same context menu like your picture.
    I only get close tray and eject tray separately..
    I am using windows 7 64bit
  5. Posts : 72,051
       #14
    Hello madmax,
    The context menu added by the tutorial is only for when you right click on an empty area of your desktop.
    It's not added to the drive's context menu in the Computer window.
  6. Posts : 96
       #15
    Brink said:
    Hello madmax,
    Well I click on the desktop and it doesn't show that context menu
    Actually I click on the desktop just now and I get the same icon as shown in the pic now...
    Also can you post an image of what it looks like when u click on the dvd drive?
    What windows are u using?
    I am on win 7 64bit
    It would be good if u can make it show the same icon as the pic when clicking on the dvd drive.
  7. Posts : 72,051
       #16
    The context menu of a CD/DVD/BD drive doesn't have any icons, and only has the "Eject" option. It's the same in all Windows.
    Eject and Close CD/DVD Tray - Add to Desktop Context Menu-dvd.jpg
    The icon used in the tutorial is a small DVD drive.
  8. Posts : 23
    Windows 7 home premium 64
       #17
    Is it normal for the cmd.exe to flash on the screen every time you click to open/close?
  9. Posts : 72,051
       #18
    Hello usernametaken, and welcome to Seven Forums.
    Yep, it's normal for the command prompt to very quickly flash open and close when using this context menu.
  10. Posts : 23
       #19
    Ok I can live with that. And thanks for the quick reply. Also, I have my auto play turned off for cd/dvd, is there a way to add a right click play function that works the same way as this one?
