Eject and Close CD/DVD Tray - Add to Desktop Context Menu
Page 3 of 9 FirstFirst 12345 ... LastLast
  1. Posts : 72,052
       #20
    Could be, but I'm afraid I don't know how as well.
  2. Posts : 23
    Win 7 Home Prem 64
       #21
    Brink...as I said in May 2012, this s/w works well on my desktop. I tried it on an HP Pavilion g6 laptop; it would eject, but not close (I did get the quick black screen flash). The tray is very cheesey, and doesn't slide as easily as in the desktop. Could that be the reason it doesn't work? Thnx, Chris
  3. Posts : 72,052
       #22
    Hello Chris,
    Yeah, I find that it won't close on most laptops either since most need to be manually closed.
  4. Posts : 23
    Win 7 Home Prem 64
       #23
    Brink...ok, thanks. Chris
  5. Posts : 72,052
       #24
    You're welcome. It really just comes down to if the CD/DVD drive has a physical button on it that both opens and closes it. If so, then usually the shortcut will work for both as well. If not, then only for open.
  6. Posts : 2
    Windows 7 Ultimate 32 bit
       #25
    Hi Brink,
    This tutorial is exactly what i was looking for, for my Sony Optiarc 5280S - CB PLUS. I wondered if you could possibly modify the .bat and .reg files to specifically work for drive ' F ' please?
    Cheers
  7. Posts : 72,052
       #26
    Hello catonthewebb, and welcome to Seven Forums.
    Sure thing. Here are the .bat and .reg files in a ZIP below. You can use them while following the tutorial instead for the specific F: drive instead. :)
    Eject and Close CD/DVD Tray - Add to Desktop Context Menu Attached Files
  8. Posts : 2
       #27
    F drive co-operating
    Hi again Brink,
    Thank you very much, my F drive is now ejecting and closing via your files
    Have a Merry Christmas and all the best for 2014 !
  9. Posts : 72,052
       #28
    You're most welcome catonthewebb. I hope you have a Merry Christmas as well. :)
  10. Posts : 3,253
       #29
    Thanks for this Brink & have a merry Christmas.
