Eject and Close CD/DVD Tray - Add to Desktop Context Menu
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. Posts : 72,051
       #30
    IownAmoneyPit said:
    Thanks for this Brink & have a merry Christmas.
    You're welcome mate. I hope you and your family have a Merry Christmas as well. :)
  2. Posts : 1
    Win 7/64 Pro
       #31
    Can I modify eject/close CD/DVD?
    Really like the entry in Desktop Context Menu but the toggle doesn't close my HP laptop which seems to have no close mechanism. You still have to push the eject/close entry again after manually closing to keep it in sequence. Open works great and manual close is easy. How do I modify it (have already installed it) to make it open only? This is an ideal mod for laptops which, as you know, have that tiny almost-hidden open button.
    Thanks.
  3. Posts : 72,051
       #32
    Hello Subpatro, and welcome to Seven Forums.
    Unfortunately, a lot of laptop DVD drives have to be manually pushed closed since they do not have a motor to pull it closed. In this case, the context menu would not be able to close it.
  4. Posts : 39
    64
       #33
    down load did not work
    Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
    Gigabyte Technology Co., Ltd. Z68X-UD3H-B3
    Award Modular BIOS v6.00PG
    8.00 GB
    Microsoft Windows 8.1 64-bit 9600 Multiprocessor Free
    letter for my dvd drive " D "
  5. Posts : 72,051
       #34
    Hello Jarp,
    Did you download the 64-bit NirCMD, and put it in your System32 folder?
    Double check to make sure that you didn't miss any of the steps by mistake.
    Is this a tray or slot DVD drive, and is it for a laptop or desktop?
  6. Posts : 24
    Win 2000 Pro x32 SP4 / Win 7 Home Premium x64
       #35
    Hi Brink.,
    A) If you "change" the drive letter in the script file, does it "show" on the right-click desktop context menu? B) If you have dual drives you want this right-click to work for, can you "specify" the drive letter for each drive, and have 2 of these commands on the right-click desktop context menu @ the same time? Drives are E: & F: and powered open / close. C) Wonder if there's a script / program to actually add these commands to the right-click drive shortcut icons on my desktop? I am currently using HiCDEject v1.0 but the right-click on the icon beside the clock is buggy at times and this is required to "select" the drive open / close. It's a really neat little program when it works. Thanks Brink for your reply.
  7. Posts : 72,051
       #36
    Hello Chuck,
    Answers inline. :)
    No. You would need to change the .reg file for the drive letter as well since that's just the text to be displayed in the context menu. You could just add a drive letter like below to do so.
    [HKEY_CLASSES_ROOT\DesktopBackground\Shell\Eject/Close E: CD/DVD Tray]
    "icon"="imageres.dll,-30"
    [HKEY_CLASSES_ROOT\DesktopBackground\Shell\Eject/Close E: CD/DVD Tray\command]
    @="Eject-Close_CD-DVD.bat"
    Yes. You would need to modify and create two .bat files for each drive letter. You would also need to modify the .reg file to add a second context menu for the other driver letter. Substitute your drive letters below instead.
    BAT File:
    IF EXIST %TEMP%\DVDOPEN GOTO :CD/DVDCLOSE
    :CD/DVDOPEN
        echo 1 > %TEMP%\DVDOPEN
        start "" nircmd.exe cdrom open E:
        exit
    :CD/DVDCLOSE
        DEL %TEMP%\DVDOPEN
        start "" nircmd.exe cdrom close E:
    REG file:
    @="Eject-Close_CD-DVD_E.bat"
    [HKEY_CLASSES_ROOT\DesktopBackground\Shell\Eject/Close F: CD/DVD Tray]
    [HKEY_CLASSES_ROOT\DesktopBackground\Shell\Eject/Close F: CD/DVD Tray\command]
    @="Eject-Close_CD-DVD_F.bat"
    You could modify the .reg file to use the registry path below instead, but the context menu will be there for all drives, and not just CD/DVD drives.
    [HKEY_CLASSES_ROOT\Drive\Shell\Eject/Close CD/DVD Tray]
    [HKEY_CLASSES_ROOT\Drive\Shell\Eject/Close CD/DVD Tray\command]
  8. Posts : 24
       #37
    Hi Brink.
    Thank you sir for the "gorey" details! Never did learn the @ % "" stuff but know the application(s). FYI, scripts / reg file world is ALWAYS black / white, it either works and always works, or you forgot the dang " somewhere. Thanks again & i'll post a prognosis when i have "played" with the above.
  9. Posts : 72,051
       #38
    You're most welcome. If you have any questions, please feel free to ask. :)
  10. Posts : 24
       #39
    Hi Master Brink.
    It's alive, ALIVE, A L I V E! Yes, it works, for E & F drives, very simple & that's the way it is and should be. Now, to really put that grey matter to the test! There ARE programs that "add" right-click options to icon shortcuts (ie: the / my desktop drive icons for E & F) or is there a way to "specify" in the registry or system tweak to do this? The batch and Nir program work flawlessly. Thanks for your reply.
