Windows 7: Power Plan - Specify a Default for All Users
27 Jan 2017   #10
Brink
64-bit Windows 10 Pro
You're most welcome. :)
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power Plan - Restore Default Settings
How to Restore Default Power Plan Settings in Windows 7 and Windows 8 This will show you how to reset and restore all of the default Power Plans back with their default settings, or how to restore a single Power Plan back to default settings in Windows 7 and Windows 8. EXAMPLE: Default...
Tutorials
Power Plan - Create Shortcut to Change Power Plan
How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8 This tutorial will show you how to create or download shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power...
Tutorials
Changing the Default Power Plan
Hello, My computer always open in Standard Power Plan. I want it always open with High Performance Power Plan. How can I do this? I mean can I change my computer settings to start with High Performance automatically at every restart? Windows 7 Ultimate x64
Performance & Maintenance
Changing Default Power Plan
Hi , i cant be able to change default power plan (that will active on startup). I select a custom power plan but when restart it starts with . Can i change this ?
