How to Create a Shortcut to Open Windows Media Center with No Startup Animation
This tutorial will show you how to download or create a shortcut that will open Windows Media Center with no startup animation or sound.
Windows Media Center is not available in Windows 7 Starter and Windows 7 Home Basic editions.
The N and KN editions of Windows 7 have all the features that normally come with each individual Windows 7 edition, except for Windows Media Player 12 and related programs, such as Windows Media Center or Windows DVD Maker.
The N editions of Windows 7 allow you to choose your own media player and software required to manage and play CDs, DVDs, and other digital media files. If you choose to use Windows Media Player 12, downloading it, along with related software, is free.
Windows 8/8.1 Enterprise will not have Add features to Windows 8/8.1 available since there are not any features available to add in that edition.
Windows Media Center is available as an economical “media pack” add-on to your installed and activated Windows 8/8.1 Pro.
If you have Windows 8 Pro installed, then you can add Windows Media Center by buying the Windows 8 Media Center Pack.
If you have Windows 8.1 Pro installed, then you can add Windows Media Center by buying the Windows 8.1 Media Center Pack.
If you have Windows 8 installed, then you will need to buy the Windows 8 Pro Pack to have Media Center added and all the features of Windows 8 Pro.
If you have Windows 8.1 installed, then you will need to buy the Windows 8.1 Pro Pack to have Media Center added and all the features of Windows 8.1 Pro.
See: How to Add "Windows Media Center" to Windows 8 and 8.1
EXAMPLE: Windows Media Center
Media Center - Open with No Startup Animation - Create Shortcut-media_center.jpg
OPTION ONE
To Download the "Media Center - No Startup Animation" Shortcut
1. Shortcut Version that Opens Media Center in Full Screen Mode
Media_Center-Full_Screen_No_Startup_Animation.zip
B) Go to step 3.
2. Shortcut Version that Opens Media Center the Same as Last Closed
Media_Center-No_Startup_Animation.zip
B) Go to step 3.
3. Save the .zip file to the desktop.
4. Open the .zip file and extract the shortcut to the desktop.
5. Right click on the shortcut, and click on Properties, General tab, and on the Unblock button.
NOTE: If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 6.
6. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
7. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
8. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Media Center - No Startup Animation" Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut.
2. Copy and paste either location below into the location area, and click on the Next button. (see screenshot below)
(Opens how last closed)
%windir%\ehome\ehshell.exe /nostartupanimation
OR
(Opens Full Screen)
%windir%\ehome\ehshell.exe /nostartupanimation /directmedia:general
3. Type Media Center - No Startup Animation for the name, and click on the Finish button. (see screenshot below)
4. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
5. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
