Recent Items - Turn On or Off
Page 3 of 7 FirstFirst 12345 ... LastLast
  1. Posts : 72,049
       #20
    Sorry, had to make sure.
    Are these programs still installed? If so, then see if pinning the Control Panel icon to the taskbar, then try to unpin the programs.
    You might also see if you can use the program in this tutorial to remove them as well.
  2. Posts : 134
    You might also see if you cab use the program in this tutorial to remove them as well.
    pinning Control Panel to icon and unpin doesn't work.
    The program doesnt work as well.
  3. Posts : 72,049
       #22
    A repair install should be able to reset this for you without losing anything.
  4. Posts : 134
    does upgrading my os has the same effect as repair install, becoz i did an upgrade once and it doesn't help
  5. Posts : 72,049
       #24
    Sort of, but a repair install is doing a upgrade install with the same build that you currently have instead of a new build. This way it repairs the old OS instead of upgrading and replacing it.
  6. Posts : 29
    Windows 7 Ultimate x86
       #25
    Is there any way for the 'recent items' in start menu to store only certain filetypes?
    I want to see the recently opened office documents but not mp3s or videos..
    Thanks in advance,
    JaX
  7. Posts : 72,049
       #26
    Hello JaX, and welcome to Seven Forums.
    Not that I am aware of. It seems to be a all or none deal.
  8. Posts : 29
       #27
    Too bad.. Thanks anyways.. You and this forum have been of great help.. :)
  9. Posts : 72,049
       #28
    You're welcome. :)
  10. Posts : 131
    Windows 7 Ultimate x64 Service Pack 1
       #29
    I tried Option 1 and 2, but still I don't see files in taskbar, only in start menu now.
