#40
Partition Alignment does not seem to be available with the Free version.
Welcome to Seven Forums Krammig. I just downloaded and installed to confirm. Indeed it does work, although the Advanced> Partition alignment appear to be greyed out, they do indeed work
A Guy
Thanks for the feedback.
Confused through .. "although the Advanced> Partition alignment appear to be greyed out, they do indeed work" ..
The article spoke about running the partition alignment which I tried to do but as a function was not available/not selectable. It asks the user to upgrade, is that what you are also referring to as being greyed out ?
Cheers
No, it worked fine for me even though it appeared greyed out. I had no issue doing what Wolfgang shows in the tutorial. Not sure why it won't work for you, sorry. A Guy
