Reliability Monitor - Reset
Page 1 of 9 123 ... LastLast
    How to Reset Reliability Monitor in Windows 7 and Windows 8
    If you have fixed the errors or just want to clear the reported data in Reliabilty Monitor, then this will show you how to reset the Reliability Monitor back to a clean default state in Windows 7 and Windows 8.
    You must be logged in as an administrator to be able to do this tutorial.
    Reliability Monitor is an advanced tool that measures hardware and software problems and other changes to your computer. It collects 24 hours of data before it displays any results and calculates the stability index that ranges from 1 (the least stable) to 10 (the most stable). You can use the index to help evaluate the reliability of your computer by reviewing the reported application failures, Windows failures, Miscellaneous failures, Warnings, and Information. Any change you make to your computer or problem that occurs on your computer affects the stability index.
       Warning
    If you reset the Reliability Monitor, then any previously displayed data will no longer be available unless you have backed it up in step 3 below to restore.
    This does not work in Windows 8.1 Update.
    EXAMPLE: Reliability Monitor
    NOTE: You can tell your Index score (scales from 1 to 10, 10 is the best score) by looking at how the chart line ends in the upper right corner boxed in red below compared to the scale of 10 to 1 on the left upper corner boxed in red below.
    Here's How:
    1. Click/tap on the Download button below to download the file below, and save it to your desktop.
    NOTE: Special thanks to Zardoc for providing the part in the BAT file to clear the Event Viewer logs.
    Reset_Reliability_Monitor.bat
    Download
    2. Unblock the .bat file.
    3. Right click or press and hold on the downloaded .bat file and click/tap on Run as administrator.
    4. If prompted, click/tap on Yes (UAC).
    5. You will now see a command prompt open, run the commands to reset Reliability Monitor, then close.
    6. If this is for Windows 8 and 8.1, then you must repeat steps 3-5 to run the .bat file a second time for this to work.
    7. When finished, restart the computer to fully apply.
    It may take Reliability Monitor a few to 24 hours to display results again after being reset.
  1. Posts : 5,807
    This is still cheating Shawn
  2. Posts : 72,050
    LOL, not if you fixed the issues.
  3. Posts : 5,807
    lmao...I was under the impression that Windows 7 would "erase" fixed issues off your record
  4. Posts : 72,050
    Nope, they will still show up in the Reliability Monitor's history report.
  5. Posts : 5,807
    It is hard to get "crimes" off your record huh
  6. Posts : 72,050
    LOL, yep.
  7. Posts : 48
    Windows 7 ultimate 32 bit
    hi im new to this site and good Tutorial man but is it bad to reset it or no and i didn't back up the folders they weren't that important.. if i get new errors will they show up in my reliability monitor?
  8. Posts : 524
    Windows 7 SP1 x64
    After some time (a few hrs.) it will reset your index to 10 and it will start to show new errors(lowering your index of course)
  9. Posts : 38
    Windows 7 Ultimate 32 bits
    Thanks a lot for this, it sure worked like a charm! :)
    Now I got rid of the evidence of the crimes
