#40
About that batch file.
Under Windows 8 Pro.
I thought you might like to see this. The reg set command does not work. Apparently, there is no 'set' option for reg.exe in Windows 8. You have to create a .reg file and use IMPORT.... (at least I think that's the way you do it, not sure)
Secondly, The batch file cleared the logs and deleted the Reliability Monitor's database alright, but now two days later my reliability monitor seems to be broke. It's not collecting any data at all. Maybe it will in a few days.
Lastly, I'm not sure if this is related but in the task scheduler I see RACTask is running, and running, and running.... I think something is broke. I'm not sure what at this time.
