Reliability Monitor - Reset
Page 9 of 9 FirstFirst ... 789
  1. Posts : 72,059
       #80
    That's correct. RACAgent.exe is not in Windows 8.1.
    If you like, you could use perfmon /rel to directly open Reliability Monitor with instead.
    Reliability Monitor Shortcut
  2. Posts : 14
    Windows 7 Home premium 64 bit
       #81
    Hi Brink
    My problem: Windows 7 64bit Home Premium, When I open the Reliability Report, sometimes it is populated with data, I can reopen the report 10 minutes later and the report is bare, with no data or even a date, (refreshing the window, causes the same problems), sometimes the data is there but it can be a week behind! Then checking again...everything is back to normal. I tried installed an image from May 2015, but on updating the programs and software I still have the same issues. Very unstable! Will this bat file correct my issues?
    In anticipation, Thanks
  3. Posts : 72,059
       #82
    Hello Stu, :)
    It depends on what's wrong with it, but if it's just some corruption it may help.
  4. Posts : 44
    Windows 7 Professional
       #83
    Hi Brink,
    It is possible to reset the reliability monitor without erasing the informational events (Updates, etc.)?
  5. Posts : 72,059
       #84
    Hello Jorge,
    Not that I'm aware of.
  6. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #85
    Just wondering does system protection have to be enabled for this to function ?
    Okay switched to weeks and it showed activity in the blue line :)
  7. Posts : 72,059
       #86
    System Protection should have no affect on this. :)
  8. Posts : 20,583
       #87
    Seems so it sort of freaked me out a tad not showing any errors
    Or successful updates installs either which it used too :/
  9. Posts : 44
       #88
    Brink said:
    Hello Jorge,
    Hi Brink,
    By accident, once I was running the file and rebooted the notebook. The information events still there and the rest was gone.
    I am wondering if it is a command line that didn't run because of the reboot!
  10. Posts : 72,059
       #89
    The reboot must have interfered before it cleared the events. Hopefully, the others won't be restored after the next restart without it being fully reset.
