#50
Thanks, much appreciated.
Hi Selvan,
Here. LOL.
CreateImage.zip
You will find that all the tutorials on all the forums are virtually identical - on every subject.
You can bet that there will be tutorials about making a "system image shortcut" springing up all over the place now.
That is a great find Simon. This tutorial is credited to you.
Create a System Image Shortcut - Create
Thank you very much for sharing this. :)
I am wondering instead of downloading imgburn. I saved the file to a folder in my files. Then I put in a DVD in my DVD burner. I then went to the file right clicked selected open with. Then I selected windows disk image burner. and I burned it to my DVD. Does that work like that. Or do I have to download imgburn? The file size is 169,650. I am pretty sure it is the same thing they almost have the same name. I just would like to make sure.
Can I do this with Daemon tools? and mount the ISO instead of burning it?
Thanks,
The Unofficial
