System Repair Disc - Create
Page 9 of 20 FirstFirst ... 789101119 ... LastLast
  1. Posts : 71,977
       #80
    Hello Preiius, and welcome to Seven Forums.
    Both 1 & 2 = Can be used on either.
    Both 3 & 4 = Yes on both.
  2. Posts : 68
    Windows 7 Professional 64bit
       #81
    Really, my understanding was win7 non-sp1 cannot repair sp1 installation, or that win7 sp1 cannot repair non-sp1 installation.
    Btw, great forum.
  3. Posts : 71,977
       #82
    Yep, I just tested by booting to the "System Recovery Options" screen from my 64-bit non-sp1 Windows 7 installation disc at boot on my 64-bit Windows 7 SP1 installation, and was able to do all options. :)
  4. Posts : 168
    Windows 10 Home 64b
       #83
    I have created 2 System Repair Disc cd's and they won't boot. I have tried changing the order of boot in BIOS and used F12 too to quickly select drive to boot. Only a System Repair "USB" boot and a retail Windows 7 DVD.
  5. Posts : 71,977
       #84
    Hello LM,
    If you have your CD/DVD drive set to be first in the boot order on BIOS, then when you get that "Press a key to boot from CD..." message at boot, are you pressing a key at that point to boot from the system repair DVD?
  6. Posts : 16,129
    7 X64
       #85
    1. Why do you want a system repair disc if you have the retail dvd?
    2. If it's for a backup copy of the repair functions - try using a recordable dvd to create the repair disc.
      My Computers
  7. Posts : 168
    Windows 10 Home 64b
       #86
    Because is not booting neither and tried making the repair discs, stupid laptop. I don't know what's wrong.
  8. Posts : 71,977
       #87
    LM,
    Are you able to boot from a USB flash drive using your boot menu (F12 ?) ?
    If so, you could use the tutorial below to create a Windows 7 installation USB flash drive to use to boot to the "System Recovery Options" screen with instead.
  9. Posts : 16,129
    7 X64
       #88
    You say the win 7 install dvd will boot ?
    Did you read the second question?
    I don't usually repeat myself - but English is not your first language , so you may have missed it.
      My Computers
  10. Posts : 168
    Windows 10 Home 64b
       #89
    I can boot from USB, but not from the dvd as before and i don't know what's wrong because the dvd\cd drive read it well in Windows, the problem is just booting from it.
