System Repair Disc - Create
Page 10 of 20 FirstFirst ... 89101112 ... LastLast
  1. Posts : 72,064
       #90
    LM,
    Since you say that you have the CD/DVD drive listed as first in the boot priority list in BIOS, and have selected to boot from it in your F12 boot menu, are you pressing a key to actually boot from the CD/DVD drive when you see this screen below pop up? If not, then it will not boot from the CD/DVD drive even if listed first.
  2. Posts : 168
    Windows 10 Home 64b
       #91
    Message is not appearing as before.
  3. Posts : 72,064
       #92
    Personally, I'd stick with using a USB flash drive since it will be faster with it.
    If you're not seeing the "Press any key..." message, then the CD/DVD drive is not set to be allowed to be booted from in BIOS or boot menu.
  4. Posts : 3
    Pennsylvania
       #93
    I want to create a backup image of my Windows install and put it on my Areca RAID array. Can a recovery disc be made with those RAID drivers?
  5. Posts : 72,064
       #94
    Hello Ramicio,
    Not that I'm aware of.
    As a workaround, you could create a ISO of the repair disc, burn the ISO to a USB flash drive, and then manually copy the RAID drivers to the USB flash drive to make it easier to select them.
  6. Posts : 3
    Pennsylvania
       #95
    There is evidently a way to make a USB recovery disc without the tool. But still, it would have been nice for them to enable a way to include RAID drivers.
  7. Posts : 21,004
       #96
    Thanks Shawn Haven't this mistake again with the newy laptop (my little Compaq CQ43 workhorse - pun intended lol!!)
    John
  8. Posts : 72,064
       #97
    LOL, no problem John. :)
  9. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
       #98
    I'm assuming the System Repair Disk is the same as pressing F8. I don't know, never tried this before.
  10. Posts : 72,064
       #99
    Hello Infinite,
    Yeah, they both will boot to the "System Recovery Options" screen. Some custom factory OEM installations may vary with what F8 does though. :)
