System Repair Disc - Create
Page 12 of 20 FirstFirst ... 21011121314 ... LastLast
  1. Posts : 64
    I think this is just for repairing disc and nothing else.
    Any way great tutorial.Thanks
  2. Posts : 72,055
       #111
    Hello Katherine,
    That would be correct. :)
  3. Posts : 64
    yes it would.....Thanks Brink
  4. Posts : 182
    Windows 7 Home Premium 64bit OEM
       #113
    I can't make my own System repair disc.
    Attached Thumbnails Attached Thumbnails System Repair Disc - Create-cant-make-system-repair-disc.png
  5. Posts : 16,163
    7 X64
       #114
    Hi Papin,
    That is because you have an oem machine ( Other Equipment Manufacturer , e.g. Acer).
    On some oem machines you cannot use microsoft repair disc creator from the original operating system.
    If you installed windows 8 - you can try booting into that and see if you can make windows 8 repair disc.
      My Computers
  6. Posts : 6,618
       #115
    OEM = Original Equipment Manufacturer.
  7. Posts : 182
       #116
    Yeah, you're right.
    I don't want to, because in my HDD, have Recovery disc
    Attached Thumbnails Attached Thumbnails System Repair Disc - Create-recovery-partition.png
  8. Posts : 3
    Windows 7 64-bit
       #117
    Following the directions, I get the exact same message as the first post. It doesn't even try to look at the DVD drive.
    Does not work for me. Problem stays the same.
  9. Posts : 16,163
    7 X64
       #118
    What first post?
    The first post in the thread says Thank you Shawn.
      My Computers
  10. Posts : 3
    Windows 7 64-bit
       #119
    I believe that was the last post. The original post stated the problem, that Win 7 would not create a repair disc, with the message "The parameter is incorrect. (0x80070057)"
