#110
I think this is just for repairing disc and nothing else.
Any way great tutorial.Thanks
yes it would.....Thanks Brink
Hi Papin,
That is because you have an oem machine ( Other Equipment Manufacturer , e.g. Acer).
On some oem machines you cannot use microsoft repair disc creator from the original operating system.
If you installed windows 8 - you can try booting into that and see if you can make windows 8 repair disc.
OEM = Original Equipment Manufacturer.
Following the directions, I get the exact same message as the first post. It doesn't even try to look at the DVD drive.
Does not work for me. Problem stays the same.
What first post?
The first post in the thread says Thank you Shawn.
I believe that was the last post. The original post stated the problem, that Win 7 would not create a repair disc, with the message "The parameter is incorrect. (0x80070057)"
