System Repair Disc - Create
Page 17 of 20 FirstFirst ... 71516171819 ... LastLast
  1. Posts : 11,408
    ME/XP/Vista/Win7
       #160
    You can not use a USB Pendrive to do a startup Repair, as startup repair will find the MBR on the Pendrive & not the HD.
    Therefore will not detect a problem.
    Windows Vista or Windows 7 no longer starts, and the Startup Repair tool does not fix the problem
  2. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #161
    Thank you theog
    FredyC, DON'T do post # 159
  3. Posts : 37
    Windows 7 Enterprise 64bit
       #162
    Oh snap, it looked like nice and sophisticated solution :) So I guess my solution with virtual burner still applies, I just have to try it.
  4. Posts : 1
    Window 7 64 bit
       #163
    where is repair disk
    I can not find anywhere on this page to download the repair disk.
  5. Posts : 72,046
       #164
    Hello Joell, and welcome to Seven Forums.
    The tutorial is for how to "create" a system repair disc instead. It would be a violation of Microsoft's copyrights and distribution policy to have one available for download.
  6. Posts : 12
    Window 7 Ultimate 32bit
       #165
    A very nice tutorial Brink and thanks for sharing.
    It is a nice help. When you got trouble.
  7. Posts : 72,046
       #166
    Welcome to Seven Forums David. I'm glad it was able to help. :)
  8. Posts : 2
    Windows 7 Home Premium 32-bit
       #167
    I have Windows 7 Home Premium 32-bit. I assume that if I needed to create a repair disc using someone else's computer, that it has to be this version of Win 7 in addition to being 32-bit. Is that correct, or can it be any Win 7 OS that has 32-bit?
  9. Posts : 72,046
       #168
    Hello Roadrunner, and welcome to Seven Forums.
    That's correct.
    However, if you have a retail 32-bit Windows Home Premium installation USB/DVD, then you could use that instead since it also includes this.
    Windows 7 USB/DVD Download Tool
    (see the blue note box at link for details about an ISO file)
    Hope this helps, :)
  10. Posts : 2
       #169
    Unfortunately I don't have the install disc because I downloaded from Microsoft, then copied the files to my flash drive after installation. That's why I'm scrambling to find someone with the same OS, so I can get the repair disc. I have an NTLDR error message that I'm trying to resolve.
