Windows 7: System Repair Disc - Create
How to Create a Windows 7 System Repair Disc
Published by Brink
14 Jan 2009
information   Information
This will show you how to create a Windows 7 system repair disc to be able to use to boot to system recovery options to help recover your Windows 7 installation if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer.
A system repair disc is not able to install Windows 7.
Note   Note
If you are unable to boot your Windows 7 to create a Windows 7 System Repair Disc, then you could create it on another computer to use on your computer.
warning   Warning
  • A system repair disc is not the same as a OEM factory recovery/restore disc.
  • A system repair disc is not an installation disc. You cannot do a repair install or install Windows 7 with a system repair disc.
  • A system repair disc can only be used to repair Windows 7 through the system recovery options.
  • 32-bit System Repair Disc can only be created on a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be created on a 64-bit Windows 7.
  • 32-bit System Repair Disc can only be used to repair a 32-bit Windows 7.
  • 64-bit System Repair Disc can only be used to repair a 64-bit Windows 7.
For Windows 10, see the following link - System Repair Disc - Create in Windows 10 - Windows 10 Tutorials
EXAMPLE: System Recovery Options
NOTE: Using the System Repair Disc that you have created below, you can boot to the system recovery options screen below.
Here's How:
1. Open the Start Menu, then type recdisc.exe in the search box and press Enter.
A) Go to step 3.
OR
2. Open the Control Panel (icons view), and click on the Backup and Restore icon.
A) Click on the Create a System repair disc link in the left blue pane. (See screenshot below)
3. Insert a blank unformatted CD or DVD into your CD/DVD drive and click on the Create disc button. (See screenshot below)
NOTE: If you are prompted to insert a Windows installation disc, it means that the files needed to create the system repair disc cannot be found on your computer. Insert a Windows 7 installation disc.
4. It will now start creating the System Repair Disc. (See screenshot below)
NOTE: If a AutoPlay window pops up, just close it.
5. When it's finished, click on the Close button. (See screenshot below)
6. Click on OK. (See screenshot below)
7. Remove and label your new Windows 7 System Repair Disc from the CD/DVD drive.
Tip   Tip
If you would like to create a bootable System Repair USB flash drive, then you could use the free program ImgBurn to create an ISO file with this Windows 7 System Repair Disc (DVD), then use the Part 1 section in the tutorial below to extract the ISO file to a USB flash drive.
Windows 7 USB/DVD Download Tool
15 Jan 2009   #1
Mark
Very nice, thank you Shawn.
15 Jan 2009   #2
echrada
Thanks just made mine.
15 Jan 2009   #3
Brink
64-bit Windows 10 Pro
You're welcome MR GRiM and Echrada.
19 Jul 2009   #4
Brink
Hello Rakcs,
Unfortunately this method will only let you create one using a DVD. However, you can create a Windows 7 installation USB key to use to do the same thing with instead from your Windows 7 ISO file.
30 Aug 2009   #5
Oblomow58
Win7 x64 SP1, Virtual Hackintosh
Recovery console like in in WinXP
Hi all,
I have a bunch of questions on that repair disk issue.
Does that procedure include 3rd party disk drivers (like the Intel storage management drivers for RAID) include into that repair disk.
Is it necessary to produce one DVD per installation or is it a universal approach, where I can produce the repair DVD just once?
In WinXP it was possible to do something similar by entering
WinNT32 -cmdcons and you got a second instance of the OS for repair tasks - that was very useful some times (disable freshly installed hardware services which prevent XP from boot).
Is there a similar option in Win7?
Or is it possible to
manally generate the Repair DVD,
transfer that content to a VHD-File
and
enable that VHD as a addition boot option in BCDedit
Actually I run the Ultimate RTM x64 from MSDN so VHD-boot is allowed
Thanks for your comments and advices
Oblomow
30 Aug 2009   #6
Brink
Hello Oblomow,
This only creates a repair disc that boots to the System Recovery Options screen to allow you to only repair any Windows 7 on any computer with. It does not install Windows 7, but you can use the command prompt option to run commands though.
17 Sep 2009   #7
igorotak
windows 7
nice tutorial, thanks for sharing
17 Sep 2009   #8
Brink
You're welcome Igorotak. Thank you.
18 Sep 2009   #9
Eneswar
MS Windows 7 Home Premium 64-bit SP1
Thank you for this!
Create System Repair Disc
Trying to create a system repair disc I get error #0x80004005. It appears to have something to do with Outlook--I do use 2010 Office Outlook. Any help is greatly appreciated!
Performance & Maintenance
Cannot create system repair disc
I am unable to create a system repair / recovery disc by either running recDisc.exe or using the option to create a recovery disk in Backup and Retore. It says System Repair Disc could not be created. "The parameter is incorrect (0x80070057)" I have tried using both a blank CDr and a DVDr. I am...
Cannot create system repair disc.
Known good cd drive & dvd drive installed in my pc. Known good Taiyo Yuden cd & dvd discs. Tried discs separately in each drive three ways. Have tried Search box typing recdisc.exe. Have tried going through Control Panel to reach the part to create repair disc. Have tried using an...
Backup and Restore
Create a System Repair Disc
Using Windows 7 Backup and Restore, I am attempting to create a disc to save: "Create a System Repair Disc" However, when I put in a blank DVD-R disc, that's not been used, the message comes up: "The disc in the selected drive is not blank" I've tested the DVD disc and it comes out fine.
How often should I create a system repair disc?
Hello, I have created a system repair disc for both of my PCs. I also create system backups on a regular basis. Should I also create system repair disc on a regular basis? I have recently changed the drive letter of several of my external hard drives, whould this require a new repair...
Backup and Restore
Hi all Windows updates have been doing some unpredictable things to my system so I have done a system restore and and now creating a mirror image using the tutorial on this forum. I read that it should only take about 15 mins and need over 1GB of space to do this (I am backing up on a DVD as I...
Backup and Restore
