Bootmgr - Move to C:\ with EasyBCD
Page 1 of 15 12311 ... LastLast
    Bootmgr - Copy to C:\ with EasyBCD
    How to Copy the Bootmgr to C:\ with EasyBCD
    Copying the bootmgr from the 100MB active partition or the recovery partition to C:\ is extremely simple with EasyBCD. You can download a free EasyBCD from this website.
    The bootmgr will not be moved from the original location - it will only be copied to the C:\ partition. The C:\ partition will be activated and the 100MB partition will be deactivated.
    NOTE: The free version download of EasyBCD is at the bottom under "Download free for limited, non-commercial use". Registration is not required to download.
    The steps to take are very simple and explained in the 2 pictures. The first screen you get after starting EasyBCD and the second screen after step3 of the first screen. That is really all you need to know.
    Bootmgr - Move to C:\ with EasyBCD-2012-01-21_2344.png
    Bootmgr - Move to C:\ with EasyBCD-2012-01-21_2348.png
  1. Arc
    Very informative, Wolfgang !!
    Used EasyBCD many a times, but didn't know that feature .
  2. Posts : 12,177
    Nice and easy to follow, will be very useful to link when required.
    Thanks whs.
  3. Posts : 14,606
    excellent tutorial WHS,
  4. whs
    Thanks guys. I am glad you find it useful
  5. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Awesome find. This will save me one primary partition. Thanks for the tutorial.
  6. whs
    I am glad you can make good use of it.
  7. Posts : 1,167
    Windows 7 Pro with SP1 32bit
    It would perhaps have been more awesome if it was a portable execute file instead of having to install another program. Otherwise an excellent little program.
  8. whs
    I agree with you. Maybe SIW2 can find a way to put it on a WinPE stick. He is the expert on that. I am still struggeling to understand how to manhandle this WAIK.
  9. Posts : 3,133
    Windows 7 Home Premium 64bit SP 1
    Thanks for the great tutorial whs. It worked like a charm for me.
