Bootmgr - Move to C:\ with EasyBCD
Page 8 of 15 FirstFirst ... 678910 ... LastLast
  1. Posts : 7
    Windows 7 Home Premium 64 bit
       #70
    Ok, sounds good. Thanks again for all your help.
  2. Posts : 22,814
    W 7 64-bit Ultimate
       #71
    Well done Wolfgang.
  3. whs
       #72
    Thanks Ted.
    Looks like they have a boot disk available now. You might want to add it? Easy Recovery Essentials - NeoSmart Technologies
    Anyone tried it?
  5. Posts : 1
    Win 7 Ultimate x64
       #74
    Thanks. It helped.
  6. Posts : 1
    Windows 7 64-bit (home?)
       #75
    Awesome! You fixed my computer - been working on it for 5 hours now lol!!
  7. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #76
    Hi Wolfgang,
    I guess the boot file has been copied over to C after doing this tutorial but what can we do with the first or original partition it's on
    I really don't like the it being on dual boot anymore with this 400mg partition :/
    Yikes now it's listed as E
    Accessing it says it's empty ?
    Attachment 338697
    Delete E in Disk Mgmt, boot Partition Wizard disk, rightclick C to Resize, drag left border all the way to left, click OK, Apply.
  9. Posts : 20,583
       #78
    Thanks Greg,
    Looking at the free space on E it does seem to have something on it ?
    Can I delete with mini tool ?
    I thought we created that partition a few weeks ago to be the System Reserved partition? Did you change it to C recently? Why?
    If you want the 400mb onboard C then resize otherwise you can just delete it as it is useless now that the System Active flags are moved to C.
