BitLocker Drive Encryption - Unlock a Locked OS Drive
Page 4 of 4 FirstFirst ... 234
  1. Posts : 4
    windows 8.1 pro 64 bit
       #30
    i have entered exactly the same recovery key which matches the identifier code
  2. Posts : 4
       #31
    after running that recovery command my drive is status is this whats this means now
    Attached Thumbnails Attached Thumbnails BitLocker Drive Encryption - Unlock a Locked OS Drive-screenshot-5-.png
  3. Posts : 72,058
       #32
    From your screenshot, it looks like it may be a permissions issue instead.
    As a test, use the tutorial below to add a "Take Ownership" context menu, then take ownership of the E: drive to see if that may allow you to be able to access it afterwards.
    Take Ownership - Add to Context Menu in Windows 10 - Windows 10 Forums
