License Information for Windows 7
Page 1 of 4 123 ... LastLast
    How to See Windows 7 License Information
    How to See Your Windows 7 Licence Information
    This is a fool-proof way to check your Windows 7 licence information using the command prompt, especially handy if you're using an evaluation copy of Windows 7
    Using winver alone doesn't necessarily display the correct expiration date, nor the license status
    1. Open a command prompt by pressing the Winkey+R, typing cmd into the address bar and hitting enter.
    2. In the command prompt type;
    slmgr and hit enter.
    A Windows Script Host will pop up informing you of an invalid combination of command parameters.
    In the script host you'll be shown Global Options, Advanced options, Volume Licensing: Key Management Service (KMS) Client options, Volume Licensing: Token-based Activation Options & Volume Licensing: (KMS) Options.
    For most, the global options will do. The most frequently used command will be to check the licence status and expiration date.
    3. To display the current license information type into the command prompt;
    slmgr /dli and hit enter.
    4. To display detailed information on the current license type into the command prompt;
    slmgr /dlv and hit enter.
    5. To display the expiration date for the current license type into the command prompt;
    slmgr /xpr and hit enter.
    If an evaluation copy of Windows is being used, the rearm command may be used up to three times to extend the grace period. Grace period, and rearm counts are displayed by using slmgr /dlv
    6. To rearm Windows and extend the grace period, in the command prompt, type;
    slmgr /rearm and hit enter.
    7. Restart your system to apply the changes.
  1. Posts : 20
    Windows XP and Windows 7 Ultimate x86
    Cant we change the key to make it a permanent one?
  2. Posts : 71,980
    Hello Prudhivisekhar,
    I'm not sure of what you mean, but this will show you how to change the product key number to have Windows 7 activated using it instead. If you use a legal valid pruduct key number, then you can make it your permanent one by not having to change it.
    Product Key Number - Change
  3. Posts : 68
    Windows 7 Pro x64
    nice to know this.
    thanks m8
  4. Posts : 1,065
    You're welcome JoHn87
  5. Posts : 109
    Windows 7 Home Premium 64 Bit
    Thanks for this great tutorial!
  6. Posts : 285
    Very nice tutorial!
    Hope to see more tutorials from your hand ;-)
    Best regards,
    zx81
  7. Posts : 1,065
    You're welcome zx81 :)
  8. Posts : 12,177
    Great tutorial,
    Very useful info.
    Thanks M8
  9. Posts : 9
    Win7 Ultimate 64
    Question about the "legal valid product key". Can you enter a valid "Ultimate Upgrade" key? I want to get legal but also want to make sure I buy the version that will allow me to enter a key after the rearm winds down and not require any re-install. If you can enter an "Upgrade", I'm wondering how you would then be required to prove you had the pre-requisite upgrade base product.
