#30
This is the error I get
the affected drive is F and I want to be restored to the C drive.
This is what happens evertyime I enter the recovery ID, I am simply unable to attain any sort of access to the drive.
You won't be able to recover F: to C: since C: is the Windows drive. You'll need to recover F: to a different drive letter.
I have entered another external drive in G and the error persists, am I typing the command correctly?
I don't see any issues with the command.
Is the G: drive of equal or larger size than the F: drive?
If you have the BitLocker recovery key for F: , then you might try the command in step 3 for it instead.
I will try the recovery ID as a method of recovery also.
I have a 250GB 2.5" as my external, the drive I am trying to recover from is a 320GB 2.5" but the data is not more than 150GB.
does the drive itself need to be equivalent to or larger than the affected drive?
so in other words I will a 320GB or more?
Yep, the amount used doesn't matter. You will need a drive at least 320GB or more to recover to.
Please see this error again.
I am trying to recover :F(320GB) to drive :H (320GB).
Am i doing something wrong?
I don't see any obvious issue with the syntax of the command.
Try the command below to see how it does without -f instead:
repair-bde F: H: -pw
