BitLocker Drive Encryption - Unlock a Locked Data or Removable Drive
Page 7 of 8 FirstFirst ... 5678 LastLast
  1. Posts : 2
    W10P
       #60
    Yes I can access the data but I aim to boot from the SSD rather than backup the data , install and configure, which will take me a day or more
    Tobias
  2. Posts : 1
    Win 7 Ultimate x64
       #61
    Hi
    I have a encrypted drive -data only (on a laptop with TPM) & keep the password (which I had entered when the drive was encrypted). Now my OS drive is dead (win 7 Enterprise x64) & I have replaced a new one with new OS (win7 Ulti x64). CAn I unlock the encrypted data drive with new OS?
  3. Posts : 72,084
       #62
    Hello mabu85, and welcome to Seven Forums. :)
    If you have the BitLocker password or recovery key for the encrypted data drive, then you should be able to unlock it from within the new OS.
  4. Posts : 1
    windows 7 E
       #63
    Hi My external Hard drive encrypted using Bitlocker..
    I have the encryption key and couldn't open the drive using key .
    I tried to using command prompt
    this was the result can you explained what happned to External Drive please .
    Any luck to access to the data please ?
    BitLocker Drive Encryption - Unlock a Locked Data or Removable Drive-status-1.gif
    BitLocker Recovery Key B6771FC7-482A-4A63-AAB0-F5DBB0E31552.txt
    BitLocker Drive Encryption - Unlock a Locked Data or Removable Drive-resuls.gif
  5. Posts : 72,084
       #64
    Hello anissanka, and welcome to Seven Forums. :)
    If you have another drive the same size or larger than this one, you could use an option in the tutorial below to try and recover the data on it.
    BitLocker Repair Tool - Recover Drive in Windows 7 and 8
  6. Posts : 1
    Windows 7 ultimate 64bit
       #65
    Jan Cronje
    Hello Team, I am in desperate need for help. I am using the external drive on my Dell laptop since the internal drive (C:) has crashed. Drive F: is asking for the recovery key to unlock the drive. I didn't use this drive for quite a while and lost the page where I kept the recovery key. Is there a way that I can recover the key again? One of my books that I have to submit to the publisher is stored on this drive. I sincerely hope that you can assist me. I thank you for you time and I am looking forward to hearing from you.
    Kind Regards
    Jan Cronje
  7. Posts : 72,084
       #66
    Hello Jan, and welcome to Seven Forums.
    Sorry to hear about your predicament. If you have either the BitLocker startup key, password, or recovery key, you could use the method in the tutorial below to recover the BitLocker drive to another drive that's at least the same size.
  8. Posts : 2
    Windows 10 x64
       #67
    In my Company, one laptop was encrypted by bitlocker before joining group's domain.
    Now, HDD in it was locked somehow, and it won't accept the recovery key.
    When Windows prompts and shows part of the Identifier (AE8ED0B0) it matches the same one on the print-out from when it was encrypted, but when entering the Recovery Key into prompted field, it says "this key doesn't match the drive".
    Any help, other than asking for password, because the user that was using the laptop says he didn't put any password (doubt)...
    Thanks in advance
  9. Posts : 72,084
       #68
    Hello polutaKK, and welcome to Seven Forums. :)
    If able, you could try using the BitLocker Repair Tool to recover the drive.
    BitLocker Repair Tool - Recover Drive in Windows 7 and 8 Tutorial | Windows 8 Help Forums
  10. Posts : 2
    Windows 10 x64
       #69
    I've just realised that this is Windows 7 help & support, gotta go to Win10 Department, sorry for hassle.
