How to Create a "Run" Command Box Shortcut in Windows 7 and Windows 8
This tutorial will show you how to create or download a Run command dialog shortcut that you can pin and use where you like in Windows 7 and Windows 8.
EXAMPLE: Run command dialog
OPTION ONE
To Download a "Run" Command Dialog Box Shortcut
1. Click/tap on the download button below to download the
Run.zip file.
2. Save the .zip file to your desktop.
3. Open the .zip file and extract the Run shortcut to the desktop
4. Right click or press and hold on the
Run shortcut, and click/tap on
Properties,
General tab, and on the
Unblock button. (see screenshot below)
NOTE: If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 5 or 6 below.
5. In
Windows 7, you can now
Pin to Taskbar or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
7. When finished, you can delete the downloaded .zip file if you like.
OPTION TWO
To Manually Create a "Run" Command Dialog Box Shortcut
1. Right click or press and hold on an empty area on desktop, and click/tap on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click/tap on the
Next button. (see screenshot below)
%windir%\explorer.exe shell:::{2559a1f3-21d7-11d4-bdaf-00c04f60b9f0}
3. Type
Run for the name, and click/tap on the
Finish button. (see screenshot below)
4. Right click or press and hold on the new
Run shortcut on the Desktop, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab. To the right of
Run, click/tap on the drop down menu, select
Minimized, and click/tap on
Apply. (see screenshot below)
NOTE: This is so the command window will not be seen flashing quickly open and closed when you use the Windows Update shortcut.
6. Click/tap on the
Change Icon button. (see screenshot above)
7. In the line under "Look for icons in this file", copy and paste the location below, and press
Enter. (see screenshot below)
%SystemRoot%\System32\imageres.dll
8. Select the
Run icon, and click/tap on
OK. (see screenshot above)
9. Click/tap on
OK. (see screenshot below)
10. In
Pin to Taskbar or
Quick Launch,
11. In
Windows 8, you can
