#30
First, I couldn't figure out how to reply without getting the window that says "reply with quote," Which was quite long, and I've noticed few others "reply with quote." So, I deleted the quote.
Thank you Brink. I will keep the information at hand and wait for one of my computer expert friends to be on hand before I attempt your solution.
Interestingly, since I posted my note about bubbles going 90 miles an hour after a while, the problem has not appeared again. Yesterday the bubbles were on for over 5 hours and still moving in slow motion. I know, give it time; they will certainly go kaflooey again, just as the blank screensaver, which I use at night, will, soon enough, refuse to work unless I hit "preview." When either screensaver won't work go on except in preview, the preview will run for forever until I hit a key or move the mouse. Quite odd.
Am I correct in assuming Microsoft knows about this problem? And is it possible, as another blogger suggested, that MS will come up with a patch or an update to fix the issue?
