AutoPlay - Enable or Disable
Page 4 of 4 FirstFirst ... 234
  1. Posts : 28
    Windows 7 Ult x64
       #30
    Thanks for advice, I will check more deeply into all the config settings TuneUp.
  2. Posts : 28
    Windows 7 Ult x64
       #31
    Brink said:
    It wouldn't hurt to check to see if TuneUp Utilities may have some setting that could affect AutoPlay.
    Hey Brink, I just check TuneUp is not the main cause.
    Then, suddenly my AutoPlay just back to normal like initial. Apparently it will turn to normal when loading a CD driver. So, firstly it should be lured with a CD driver that have autorun. Then, all devices now always keep AutoPlay popup when inserted, including USB.. it's fun, thanks Brink.
  3. Posts : 72,061
       #32
    I'm glad to hear it sorted itself out for you.
