MACRIUM REFLECT - Create Bootable Rescue USB Drive
Page 3 of 18 FirstFirst 1234513 ... LastLast
  1. Posts : 19,383
       #20
    Sorry this doesn't work for you : I agree, use the WAIK as a workaround.
    Out of interest, if you use Macrium to burn a traditional rescue CD/DVD, do you get the same error message?
    Regards,
    Golden
  2. Posts : 47
    Win 7 Pro x 64, Win 7 Starter
       #21
    Don't know because this netbook has no cd/dvd drive. And putting the ISO created by Macrium 5 on the usb drive does nothing.
  3. Posts : 10,455
       #22
    You need either to incorporate it into YUMI as in the tutorial or instead of creating the ISO Macrium gives you the option to create a bootable USB with just the Macrium PE on it.
  4. Posts : 47
       #23
    And I tried both tutorials and Yumi and Unetbooting did not work. I even tried just putting the ISO on the USB drive alone since someone here mentioned that v5 can save the ISO to the USB device. But now that I think about it, I used an image that I created earlier that day was saved originally to my desktop. Maybe I'll try creating a new ISO with Macrium and save it directly to the USB.
    As soon as I get access to my son's netbook I'll try this and if it doesn't work I'll try making the USB PE boot device.
  5. Posts : 51
    pardon me, but can i ask, can the bootable usb drive created by yumi be used for other purposes like storage, or has it become solely a bootable usb drive only and not meant for other uses (storage)?
  6. Posts : 19,383
       #25
    You can still use free space on the USB to store other items if you wish.
    Regards,
    Golden
  7. Posts : 51
    ok thank you very much
  8. Posts : 10,455
       #27
    You can use the free space but you must not disturb the existing directory structure.It is probably safest to add a new directory to the root for your stuff.
  9. Posts : 51
    thank you, that was what i did. :)
  10. Posts : 47
       #29
    I'm just not having any luck with this netbook. I downloaded the file and followed the instructions on the link below.
    Create a Custom Windows PE Rescue Environment
    I have followed every step about more than 5 times and I still cannot get it to work. Everything is like the tutorial except I never see step 4. The Rescue Media Drivers page never displays! At the end I keep getting the following error message:
    "Failed to create Win PE USB rescue media. The USB drive may be unsuitable please try another drive."
    This is a Asus Eee with Win 7 Starter and I'm using a 4GB SandDisk flash drive formatted to Fat32. Also to play it safe I have downloaded the 1.7GB file 2 separate times in case one was corrupted. And have started from scratch 3 times by uninstalling and reinstalling the WAIK.
