#80
Hi Legbiter and welcome to Seven Forums. The Macrium PE ISO is very small (200MB) so almost any USB stick will be big enough. However if you want to use YUMI to hold other ISOs then you need to take that into account also.
Brilliant, thanks for making that clear.
Whilst it was most likely to be a small footprint, that element of doubt is not a comfortable thing to carry into the production of Disaster Recovery Media. A product of post crash paranoia no doubt. . .
A 4 GB USB flash drive seems to be one of the smallest you can buy now and I have virtually all my tools on it. Includes Macrium boot iso, Partition Wizard, Windows System Repair, Hirens etc. I use Grub4Dos but YUMI would probably be the way to go.
On Macrium's support forum they recommend using UNetbootin, what's the difference between YUMI vs. UNetbootin? Or are these different tools that do the same thing?
Use any tool that does the job. For a single .iso I use Rufus and for multiples I use Yumi. But there are many more options.
It's pretty much the same thing. You would have to compare the supported distros and tools to see which you prefer. I've used YUMI for some time now and I have found it stable and able to boot just about any "Unlisted" ISO. I've not tried Unetbootin so I can't comment how good it is.
