MACRIUM REFLECT - Create Bootable Rescue USB Drive
Page 11 of 18 FirstFirst ... 910111213 ... LastLast
  1. whs
       #100
    I am not 100% certain why it would not directly create the USB stick. It is indeed only appr. 130MB and should fit on any stick.
    But if you have the .iso on your system, you should be able to get it on the stick. Try Rufus.
    And if that does not work, get the .iso from my Skydrive and try with that. With that iso you can make images and recoveries.
  2. Posts : 6,330
       #101
    xcr said:
    I tried to create a USB (No optical drive here). I cannot click next - I don't know why.
    In the screen print it says press Finish to continue.
  3. whs
       #102
    Good point David. I did not see that.
  4. Posts : 4,049
       #103
    whs said:
    It is indeed only appr. 130GB and should fit on any stick.
    I think that should say, "... 130 MB ...". :)
  5. whs
       #104
    Absolutely. Damned typo. Thanks for catching it. Is corrected.
  6. Posts : 9,600
    Win 7 Ultimate 64 bit
       #105
    Thank heavens it was a typo. I was going nuts trying to find a stick bigger than 130GB!
  7. whs
       #106
    LF, I am not used dealing with small fries any more - LOL.
  8. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #107
    There are 256GB USB flash drives.
  9. Posts : 9,600
       #108
    Uh...I was being a wee bit facetious.
    I need to burn a 64 bit Rescue disk but only have a 32 bit PC available to do this via TeamViewer. Is there a way to supply the Win7 64 bit ISO to mount to gather it's drivers during creation of the PE media? Is there any way a disk created on 32 bit Win7 will work on 64 bit i.e. 64 bit drivers will be included? The prompt says no.
    Is there a 64 bit Macrium PE ISO available online or can anyone provide one via Teamviewer? Thanks.
