#100
I am not 100% certain why it would not directly create the USB stick. It is indeed only appr. 130MB and should fit on any stick.
But if you have the .iso on your system, you should be able to get it on the stick. Try Rufus.
And if that does not work, get the .iso from my Skydrive and try with that. With that iso you can make images and recoveries.
