Clean Up Factory Bloatware
Page 4 of 7 FirstFirst ... 23456 ... LastLast
  1. Posts : 3,133
    Windows 7 Home Premium 64bit SP 1
       #30
    Thank you for this great tutorial Greg. I just used it to clean up my sister's new HP laptop. She had some stuff already installed and didn't want to lose it, so I did this rather than a clean install, which is what I would have done if it had been my laptop.
  2. Posts : 77
    Windows 7 home premium 64
       #31
    I have all items disabled in msconfig start up except my av and 1 microsoft that keeps coming back
    Do I need to disable all these programs somewhere else or is disabling them in msconfig good enough?
  3. Posts : 72,072
       #32
    Hello Vaper,
    If you just didn't want the programs to run at startup, then disabling them in msconfig would be fine. :)
  4. Posts : 77
       #33
    Thanks Brink,I will slowly uninstall them
  5. Posts : 72,072
       #34
    You're welcome. Hopefully they will not uninstall to slowly for you. :)
  6. Posts : 21,004
       #35
    Nice ref Greg however I am a dedicated Kaspersky freak so won't use the MSE and I was under the impression that Windows 7 was more fussy on the defrag it uses preferring the M$ one instead of after markets??
  7. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #36
    The Puran Defrag and w7 seem to work fine together. I use it about one a month on my data HDD.
  8. Posts : 50,642
       #37
    There is no comparing defrag done from Windows with a boot-time Defrag that has access to all of the System files. I learned this when no defrag would resolve slow reads and boot time on a HD except Puran which improved boot time by a minute.
  9. Posts : 21,004
       #38
    Thanks Gary I haven't used a defrag for so long now cos of the SSD's so the only time I use them are for fixes.
  10. Posts : 21
    Win 7 Home Premium 64 bit
       #39
    Greg and others,
    Thanks for all the help with my problem. Any idea's as to why Lenovo would put the recovery data in Q drive? I was looking at my own Lenovo which has a recovery but there is NO separate drive letter. It appears to be all part of the C drive. I made recovery disks and computer says that the Q drive can be deleted when that is done. Would deleting that be the same as taking and removing Q drive letter? I would like to keep the recovery if possible. I'm not sure how I can text the disks I made.
