Clean Up Factory Bloatware
Page 5 of 7 FirstFirst ... 34567 LastLast
  1. Posts : 50,642
       #40
    Yes, it's perfectly sound reasoning to keep the Recovery partition as the primary way to run Recovery - keeping disks as backup. This is apart from whether you decide to do the superior Clean Reinstall - Factory OEM Windows 7.
    As to why it shows up as Q partition, that is a mystery as Q partition is known to us here as a virtual letter for Office 360. But since it says Lenovo Recovery we know it should not have a letter so you can safely remove it. If you receive a warning that the partition is too full we can also help you unhide the files and reassign a drive letter to see what has written to it while it had a drive letter.
  2. Posts : 10
       #41
    tagged
  3. Posts : 21,004
       #42
    I am bit lost here I referred someone to CCleaner and got a very inappropriate reply and it is not showing up - I don't know how to / if I can reply to this person.
  4. Posts : 17,322
    Win 10 Pro x64
       #43
    They're gone now. :)
  5. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #44
    Yeah John, he talked himself into a big hammer. :)
  6. Posts : 21,004
       #45
    Sorry for really late reply haven't had chance before now. I thought probably that was the case one wonders how that person survives in the "real" world eh?
  7. Posts : 467
    Linux Mint 15 "Olivia" x32
       #46
    I see free the Puran boot-time defrag link is broken, would you actually recommend using that (I'm sure you do), because I was just about to try it for a friends computer, and I see now i can't :)
  8. Posts : 50,642
       #47
    Thanks for the heads-up. Have replaced the link with the actual Puran download here: Puran Defrag Download
    A boot-time defrag is exceptional since it gets at System files which are running otherwise. I've seen it speed up startup by a full minute when slow startup was traced to fragmentation and other defrags couldn't get to system files.
    Pairing it with Disk Check also tends to the HD better, while the Intelligent Optimizer (on Additional Operations tab) moves most-used programs to the outside of HD for faster reads. I probably run the whole shebang quarterly to semi-annually on my installs now, immediately after CCleaner.
    We've been seeing more cases of System Restore Points disappearing after any defrag, so check your System Restore points after defrag to make sure they're intact. If not post back a help thread in General so we can help you fix it in the defrag settings.
  9. Posts : 467
       #48
    your welcome! I'll give it a try next time it may be needed!
  10. Posts : 1,449
    Windows 7 ultimate 64-bit
       #49
    excellent read here Greg!!!; it must have taken ya a little bit of time to compile and post all that info to say the least; But definitely very useful and helpful info here! :)
