How to Turn Auto-hide Taskbar On or Off in Windows 7
InformationThis tutorial will show you how to turn auto-hide on or off to either hide or show the taskbar from view on your desktop until you hover the pointer over it in Windows 7.
You could hide the taskbar to create more space on your desktop.
NoteWhen auto-hide is turned on to hide the taskbar, it will remain hidden until you move the mouse pointer over the hidden taskbar location to have it temporarily pop-up until you move the mouse point away from the taskbar location. It will then be hidden again.
TipMicrosoft has made available a hotfix that will resolve a problem where the taskbar customizations are lost and reset to defaults when automatic logon is enabled in Windows 7 and Windows Server 2008 R2.
More details are available at: FIX: The Taskbar is reset to the default settings when you use the "Automatically Log On" feature in Windows 7 and in Windows Server 2008 R2.
EXAMPLE: Taskbar with Auto-hide Turned On and Off
NOTE: The right screenshow it with auto-hide turned off by default.
Here's How:
1. Right click or press and hold on an empty space on the taskbar, and click/tap on Properties.
2. Do step 3 or 4 below for what you want to do.
3. To Turn On Auto-hide Taskbar
A) Check the Auto-hide the taskbar box, and click/tap on OK. (see screenshots step)4. To Turn Off Auto-hide Taskbar
A) Uncheck the Auto-hide the taskbar box, and click/tap on OK. (see screenshots below)
Related Tutorials
- How to Pin or Unpin a Folder to the Windows 7 Taskbar
- How to Pin or Unpin a Program to the Windows 7 Taskbar
- How to Use Small or Large Icons on the Windows 7 Taskbar
- How to Lock or Unlock the Windows 7 Taskbar
- How to Move the Windows 7 Taskbar Location on the Desktop
- How to Enable or Disable Windows 7 Taskbar Button Grouping
- How to Allow or Prevent Taskbar Button Grouping in Windows 7
- How to Change the Windows 7 Taskbar Icon Width Size
- How to Pin or Unpin a Drive to the Windows 7 Taskbar
- How to Create a Taskbar Properties Shortcut in Windows 7
- How to Resize the Taskbar in Vista and Windows 7
- How to Enable or Disable Resizing the Taskbar in Vista and Windows 7
