Taskbar Auto-hide - Turn On or Off
Page 3 of 3 FirstFirst 123
  1. Posts : 72,058
       #20
    Hmm, ok. Is this happening with any specific apps?
  2. Posts : 5
    Windows 7 Home Premium 32bit
       #21
    the task bar is above every single app but google chrome. google chrome covers the task bar and i can't see the task bar until i minimize the page.
  3. Posts : 72,058
       #22
    Did you use anything to make the taskbar always on top?
    For now, you might see if this below may help to disable it.
    https://www.sevenforums.com/tutorials...le-enable.html
  4. Posts : 5
       #23
    my taskbar is always on the bottom though
  5. Posts : 72,058
       #24
    If your taskbar is above the window where you see the window behind/through the taskbar instead of below the window, then it's considered "Always on top".
