Devices and Printers - Change Device Icons with Custom Icons
Page 8 of 8 FirstFirst ... 678
  1. Posts : 72,050
       #70
    Hello eblis, and welcome to Seven Forums.
    I have updated the link. It should work for you now.
    Icons | Microsoft Docs
  2. Posts : 6,021
    Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
       #71
    Hi eblis, welcome to Seven Forums,
    If you are talking about this one: How to Make a Icon with a Image, it works for me!
    I hope this helps!
    EDIT: Brink beat me to it!
  3. Posts : 2
    win 7 32 and 64
       #72
    Thank you, usufull and working. ill give it a try
  4. Posts : 1
    Win10 64 bit
       #73
    Does this work with Win 10 too??
    new to this forum I came acrross this great tutorial, thread and tools to cutomize system icons...however, I am on win 10 and would be interrested to know if this would work on win 10 environement too? Alternatively is there the same tutorial (customized to win10) available somwhere??
  5. Posts : 1
    Windows 10 64-bit
       #74
    Dear pintree3,
    I had the exact same problem you did and found a way to solve it! I used the system prescribed to change a "Devices and Printers" icon with a custom icon, only to find that several device icons had their icon and name changed in the process to the only I had customized.
    So I did some work, and found that the key to having different icons and names for each device rested solely with having distinctly different Hardware IDs. Then, instead of deriving each Hardware ID by right-clicking the item in the "Devices and Printers" window, I instead went to the "Device Manager" and right-clicked the relevant devices there to get distinct Hardware IDs. Once I did this, I was able to to use those distinct Hardware IDs to get different icons and names for each of the devices I customized in the "Devices and Printers" window.
    I hope this helps!!!!
    Bob
  6. Posts : 79
    Good tutorial.
  7. Posts : 4
    So this tutorial doesn't help much. I have a logitech g602 wireless gaming mouse. However Windows 7 doesn't read it correctly. Windows reads the mouse as USB receiver with a keyboard icon.
    These are all the hardware associations and I'm not sure which to choose to find the correct correlation.
    Please help. I can't find the correct hardware ID.
  8. Posts : 9
    Does anyone know if there's an available online link for the Devices-and-Printers-Metadata-Authoring-Wizard.msi ? Or if someone still has a copy of it on their PC that they could upload? The Microsoft link is now a dead link.
  9. Posts : 7
    windows 7
       #78
    https://download.microsoft.com/download/f/5/4/f54f4af9-737a-4ee6-b3f8-bef68990cb62/devices-and-printers-metadata-authoring-wizard.msi
    +1 Link dead. Please, need md5sum and new link.
