Default Operating System - Change Default Boot OS
  1. Posts : 72,051
    Vista??
    I see XP and Windows 7 listed. Are you triple booting?
  2. Posts : 6
    Win7
    No just XP & Win7, I tried to miss to miss Vista... but I do triple boot with linux with a removable drive. Looks like I'll reformat, I'm not so far along into this O/S that a total re-install is out of order. It was a bit of a pain setting up the AGP video driver.. but now I know the trick it shouldn't be too long.
  3. Posts : 72,051
       #12
    I hope it goes smoother for you this time around.
  4. BAZ
    Windows 7 Ultimate x86
    Thanks for this tutorial!
  5. Posts : 72,051
       #14
    You're most welcome BAZ. :)
  6. Posts : 17
    Windows 7 Pro 64-Bit
       #15
    This is a really cool piece of work - so easy even I can understand it and I AM NOT a 'computer knowledge centre' - many thanks
  7. Posts : 72,051
       #16
    You're most welcome Topspin. Thank you. :)
  8. Posts : 207
    Windows 7 Professional 64bit
       #17
    Would the same apply to XP Home instead of Vista?
    I intend to install W7 on a separate drive leaving XP as C:\ on drive 0. Then install W7 64 as Z:\ on drive 1 labeled as Windows 7. I would prefer the auto dual boot to be applied to W7 not XP, I can then either leave XP as a backup system or later delete it altogether.
    Will the same change default boot OS work with XP instead of Vista?
    I have dwonloaded and printed the tutorials relating to dual booting, clean install, W7 ahead of XP and reserved partition which I am slowly getting to grips with.
    Thanks for any help.
  9. Posts : 72,051
       #18
    Hello Trapper,
    If done from within Windows 7, then yes. :)
    Since Windows 7 would be the last OS installed in the dual boot, it will become the default OS to be selected and run at startup by default.
  10. Posts : 207
       #19
    Thank you Brink:):)
    I was under the, misguided, impression that the first in a dual boot was always the C: drive and that first installed was first loaded. Being able to set W7 as the first to boot will be a great help.
    What an excellent forum you have here, and a mine of information to help us, less PC educated
