Operating System to Start - Change Display List Time
    How to Change "Time to Display List of Operating Systems" at Boot in Windows 7 and Vista
    This will show you how to change the amount of time in Windows 7 to display the Windows Boot Manager list of operating systems at boot and wait for you to select a OS to start before the default OS starts automatically.
    You must be logged in as an administrator to be able to do the options in this tutorial.
    EXAMPLE: Windows Boot Manager
    NOTE: This is the boot screen where you select what operating system that you would like to start. By default, you have 30 seconds to choose another operating system before the default operating system will start automatically.
    OPTION ONE
    Through Startup and Recovery
    1. Open the Start Menu.
    A) Right click on the Computer button on the dark right side and click on Properties.
    B) Go to step 3.
    OR
    2. Open the Control Panel (Icons view) and click on the System icon.
    3. In the left blue pane, click on the Advanced system settings link. (See screenshot below)
    4. Close the System window. (See screenshot above)
    5. Under the Advanced tab, click on the Settings button under Startup and Recovery. (See screenshot below)
    6. To Have No Wait Time
    NOTE: This will give you 0 seconds to choose a OS at boot. This is a good option if you only have one OS installed, or do not want or need to select another OS to start with at boot.
    A) Uncheck the Time to Display the List of Operating Systems at boot box. (See screenshot below step 9)
    B) Go to step 9.
    7. To Reset the Wait Time to Default
    NOTE: This will reset the time back to the default 30 seconds.
    A) Uncheck and check the Time to Display the List of Operating Systems at boot box. (See screenshot below step 9)
    B) Go to step 9.
    8. To Change the Wait Time
    A) Check the Time to Display the List of Operating Systems at boot box, and type in how many seconds (0 to 999) you want to specify to wait before the boot manager selects the default OS. (See screenshot below step 9)
    NOTE: Typing 0 will effectively remove the OS choice at boot. The default time is 30 seconds.
    9. Click on OK. (See screenshot below)
    10. Click on OK. (See screenshot below step 5)
    OPTION TWO
    Through System Configuration
    A) In the search line, type msconfig and press Enter. (See screenshot below)
    B) Go to step 3.
    OR
    2. Open the Control Panel (Icons view) and click on the Administrative Tools icon and System Configration.
    A) Close the Administrative Tools window.
    3. Click on the Boot tab. (See screenshot below)
    4. In the Timeout field to the right, enter a number between 3 and 999 seconds you want to specify to wait before the boot manager selects the default OS. (See screenshot below)
    5. Check the Make all boot settings permanent box, and click on OK. (See screenshot above)
    6. Click on Yes to confirm. (See screenshot below)
    7. Click on the Restart button. (See screenshot below)
    WARNING: This will restart the computer immediately. Make sure you save and close anything open that you do not want to lose first.
    OPTION THREE
    Using an Elevated Command Prompt
    1. Open an elevated command prompt or a command prompt at boot.
    2. In the elevated command prompt, type the command below and press Enter. (see screenshot below)
    NOTE: Substitute ### in the command for how many seconds (0 to 999) you want to specify to wait before the boot manager selects the default OS.
    bcdedit /timeout ###
    3. When operation completed successfully, you can close the elevated command prompt.
  1. Posts : 1,223
    Win 10 x64 Pro x64 / Ubuntu 15.10 x64
    I'm not at my Win7 PC right now, so I can't provide screen shots at the moment, but another tip for multi-core CPUs:
    At step 3 in the above tutorial, click Advanced Options, and increase the number of processes to use for the boot process. This option is disabled by default for some reason, but it's existed ever since Win 2000 if I remember correctly, I only started using it with XP though.
  2. Posts : 72,051
    Hello ZaLiTH,
    You might see if this may be able to help with this. By default, all processors or cores are used by default in Windows 7 though, even with this unchecked.
    Boot Advanced Options - Number of Processors - Vista Forums
  3. Posts : 1,223
    Hi Shawn,
    I wasn't aware that Win7 uses them all anyway, but I know from experience that it made a difference on XP, I thought it did in 7 as well. I'll test that tonight with the restart VB script I found just now though; if anything, at least to satisfy my own curiosity.
    Thanks for clearing that up.
  4. Posts : 72,051
    You're welcome ZaLiTH. Please let us know how your test results turn out. :)
  5. Posts : 94
    windows 7 professional 64 bit Version 6.1.7601 Service Pack 1 Build 7601
    @Brink
    what would, positive or adversely, happen if you check the "no GUI boot" option in the Boot tab in MSCONFIG?
    EDIT....never mind, I found the answer in another tutorial of yours
  6. Posts : 72,051
