Windows 7: Operating System to Start - Change Display List Time
How to Change "Time to Display List of Operating Systems" at Boot in Windows 7 and Vista
Published by Brink
17 Jan 2009
information   Information
This will show you how to change the amount of time in Windows 7 to display the Windows Boot Manager list of operating systems at boot and wait for you to select a OS to start before the default OS starts automatically.
You must be logged in as an administrator to be able to do the options in this tutorial.
EXAMPLE: Windows Boot Manager
NOTE: This is the boot screen where you select what operating system that you would like to start. By default, you have 30 seconds to choose another operating system before the default operating system will start automatically.
Operating System to Start - Change Display List Time OPTION ONE Operating System to Start - Change Display List Time
Through Startup and Recovery
1. Open the Start Menu.
A) Right click on the Computer button on the dark right side and click on Properties.
B) Go to step 3.
OR
2. Open the Control Panel (Icons view) and click on the System icon.
3. In the left blue pane, click on the Advanced system settings link. (See screenshot below)
4. Close the System window. (See screenshot above)
5. Under the Advanced tab, click on the Settings button under Startup and Recovery. (See screenshot below)
6. To Have No Wait Time
NOTE: This will give you 0 seconds to choose a OS at boot. This is a good option if you only have one OS installed, or do not want or need to select another OS to start with at boot.
A) Uncheck the Time to Display the List of Operating Systems at boot box. (See screenshot below step 9)
B) Go to step 9.
7. To Reset the Wait Time to Default
NOTE: This will reset the time back to the default 30 seconds.
A) Uncheck and check the Time to Display the List of Operating Systems at boot box. (See screenshot below step 9)
B) Go to step 9.
8. To Change the Wait Time
A) Check the Time to Display the List of Operating Systems at boot box, and type in how many seconds (0 to 999) you want to specify to wait before the boot manager selects the default OS. (See screenshot below step 9)
NOTE: Typing 0 will effectively remove the OS choice at boot. The default time is 30 seconds.
9. Click on OK. (See screenshot below)
10. Click on OK. (See screenshot below step 5)
Operating System to Start - Change Display List Time OPTION TWO Operating System to Start - Change Display List Time
Through System Configuration
A) In the search line, type msconfig and press Enter. (See screenshot below)
B) Go to step 3.
OR
2. Open the Control Panel (Icons view) and click on the Administrative Tools icon and System Configration.
A) Close the Administrative Tools window.
3. Click on the Boot tab. (See screenshot below)
4. In the Timeout field to the right, enter a number between 3 and 999 seconds you want to specify to wait before the boot manager selects the default OS. (See screenshot below)
5. Check the Make all boot settings permanent box, and click on OK. (See screenshot above)
6. Click on Yes to confirm. (See screenshot below)
7. Click on the Restart button. (See screenshot below)
WARNING: This will restart the computer immediately. Make sure you save and close anything open that you do not want to lose first.
Operating System to Start - Change Display List Time OPTION THREE Operating System to Start - Change Display List Time
Using an Elevated Command Prompt
1. Open an elevated command prompt or a command prompt at boot.
2. In the elevated command prompt, type the command below and press Enter. (see screenshot below)
NOTE: Substitute ### in the command for how many seconds (0 to 999) you want to specify to wait before the boot manager selects the default OS.
bcdedit /timeout ###
3. When operation completed successfully, you can close the elevated command prompt.
04 Feb 2010   #1
ZaLiTH
Win 10 x64 Pro x64 / Ubuntu 15.10 x64
I'm not at my Win7 PC right now, so I can't provide screen shots at the moment, but another tip for multi-core CPUs:
At step 3 in the above tutorial, click Advanced Options, and increase the number of processes to use for the boot process. This option is disabled by default for some reason, but it's existed ever since Win 2000 if I remember correctly, I only started using it with XP though.
04 Feb 2010   #2
Brink
64-bit Windows 10 Pro
Hello ZaLiTH,
You might see if this may be able to help with this. By default, all processors or cores are used by default in Windows 7 though, even with this unchecked.
Boot Advanced Options - Number of Processors - Vista Forums
04 Feb 2010   #3
ZaLiTH
Hi Shawn,
I wasn't aware that Win7 uses them all anyway, but I know from experience that it made a difference on XP, I thought it did in 7 as well. I'll test that tonight with the restart VB script I found just now though; if anything, at least to satisfy my own curiosity.
Thanks for clearing that up.
04 Feb 2010   #4
Brink
You're welcome ZaLiTH. Please let us know how your test results turn out. :)
23 Apr 2015   #5
vid4763
windows 7 professional 64 bit Version 6.1.7601 Service Pack 1 Build 7601
@Brink
what would, positive or adversely, happen if you check the "no GUI boot" option in the Boot tab in MSCONFIG?
EDIT....never mind, I found the answer in another tutorial of yours
23 Apr 2015   #6
Brink
4 Problems At One Time On A Windows 7 Operating System Need Help !
Problem (1) When I Try Opening A Photo Using Windows Photo Viewer I Get The Following Message : Windows Photo Viewer Can't Open This Picture Because You Don't Have The Correct Permission To Access The File Location . Problem (2) When I Open Microsoft LifeCam VX-5000 Instead Of Getting A...
General Discussion
How to change the default address display in Outlook 2007 contact list
In the CONTACTS section of Outlook 2007 there are various default settings that I don't like. But I don't find options to change them. 1. The main one is that the address box LOOKS as ONE field, but is in fact a collection of invisible fields: Street, City, State, Zip, Country. What you type in...
Microsoft Office
Default operating system list not found
I played around with a software( paragon portion manager) that installed its own boot loader for my dual boot laptop and after restoring back to its former settings, whenever I go to system properties and click on start up and recovery and then settings under the default operating system ther's...
General Discussion
help with operating system boot display time, start up repair loop
Almost a year ago, I tried to do an XP and Windows 7 dual boot on my laptop. A few weeks later, I didn't need the XP, so I deleted the partition XP was on. I continued to use 7 though the xp still remained in Windows boot manager upon startup. A few days ago, in the advanced system settings, I...
Installation & Setup
Cant change operating system
I recently sent my computer to get fixed and he had to wipe my system clean and basically start over. I chose to get Windows 7 and he installed it but now I'm trying to hook my printer up to it and it says that my operating system is still Vista. Well I went in and tried to change it to windows 7...
Windows Updates & Activation
Twitter Facebook
