Windows Does Not Start After Sleep
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 19
    win 7 and xp home
       #20
    after doing research it seems a common fault on gigabit motherboards, hopefully it will be resolved in thefinal build in october
  2. Posts : 1
    windows 7 RC 7100
       #21
    Wow and here I thought it was my computer. One thing that was different for me was my screen would flicker scrambled colors and then go black. Also when I would come out of sleep mode it would shut down and then start back up right away.
    I did change the one setting to never but I need to check my computer tomorrow and maybe change other settlings.
  3. Posts : 76
    Win 7 Ultimate SP1 64 bit
       #22
    Hey Lordbob,
    I can not thank you enough. This sleep problem has put me through hell for over a week. Let me explain “hell”. Every time it would fall asleep I would spend an awful amount of time trying to repair the start-up. My MBR would get destroyed, the start up disks for both Vista and Win 7 would not repair (dual booting), and Acronis and its start-up disk would get me into more trouble. It was hell. When I would finally stumble onto some way to finally start the computer which Oh by the way would not even post at first each time, it would finally start up with a black screen and a message that Windows is not genuine. So I would then have to waste all kinds of time reactivating. When finally running I tried many software programs to try to repair theMBR. Not know what I was doing would often make it unbootable again.
    I suspected that my problems were caused by Acronis True Image 2010 so today I finally uninstalled it although I liked the program. I felt that it was deleting my MBR and causing the sleep problem. I don’t know if I should reinstall it now or not.
    In any case you have lowered my blood pressure a lot and I can not thank you enough.
  4. Posts : 6,885
       #23
    kewl1 said:
    Hey Lordbob,
    Well, that does sound like a nasty problem. Glad you got it working now. There are plenty alternatives to that program, just look around and I am sure you will find one you will like.
    ~Lordbob
  5. Posts : 13
    Windows 7 Ultimate 32bit SP1
       #24
    I checked my settings and mine are a little different that yours.
  6. Posts : 98
       #25
    I did this and tested it several times and it seems to work though my issue is when its been asleep for a long period. My network icon remains with a red X. I checked the driver for the Marvell Yukon controller and its up to date. I think though you didn't put in your work around to go back and reset system to sleep.
    Jgiels
  7. Posts : 1
    win 7 x64
       #26
    Vann said:
    Yes it is. Mostly, when I return back from sleep I get a black screen. Hmm.
    same prob i even updated the bios i have to force shutdown and then start again
  8. Posts : 1
    hy, guys,
    I had same problem, so I have been looking for solution everywhere. Finally, I have solved this problem simply switching BIOS option ACPI SUSPEND TYPE to S3.
    I hope it can help others, too.
  9. Posts : 11
    xp
       #28
    thanks for info..
  10. Posts : 3
    Windows 7 64-bit
       #29
    I've been having the same problem off an on for the past few months. I'll put my computer to sleep, then everything will power on, except I get a black screen.
    This issue will go away for a week or two then come back randomly. I've been trying everything...
