Start Menu Button - Change
Page 1 of 19 12311 ... LastLast
    How to Change the Start Menu Button in Windows 7
    This will show you how to change the Start Menu button orb in Windows 7 32-bit and 64-bit.
       Warning
    REMEMBER TO BACK UP EXPLORER.EXE!
    Here's How:
    For custom made start buttons, and further information, please visit this thread: https://www.sevenforums.com/customiza...uttons-92.html
    The explorer.exe you want to edit is:
    C:\Windows\explorer.exe
    and not C:\Windows\SysWOW64\explorer.exe (for those running x64)
    And for those who use the larger DPI's i.e 125% , 150% you need to change:
    6806 - 66 x 198
    6807 - 81 x 243
    6808 - 106 x 318
    NOTE: The start orb replacement always HAS to look like this:
    1 orb: Orb when not in use (when not clicked or mouseover'ed)
    2 orb: mouseover
    3 orb: When start orb is clicked
    1. Download Restorator (Shareware) (Restorator 2007 Resource Editor - Restorator - Bome Software)
    2. Take ownership of the whole Windows folder (see these links for more info: Take Ownership of file - Vista Forums and Take Ownership Shortcut)
    3. Open explorer.exe with restorator
    4. Go to the folder called "Bitmap"
    5. Replace 6801.bmp, 6805.bmp, and 6809.bmp (as seen on the picture, you will need to right click and click assign, and then click assign to, then select your file.)
    6. Go to "file" and Save as explorer.exe on your desktop
    7. Go to the windows folder and rename explorer.exe to explorer.exe.bak and then copy-paste the new explorer, Kill the process in task manager and start it again.
    Now you have a new start button!
    Please comment, if you have something to say :)
  1. Posts : 185
    Windows 7 Ultimate 32 bit
    Sweet! Awesome tutorial thanks muchly
  2. Posts : 4,755
    You're welcome :)
  3. Posts : 8,398
    ultimate 64 sp1
    the three bitmaps we need to replace - i assume they are normal, mouseover and clicked?
    i think it would be useful if you could make this clear in the tutorial.
    oh, and thanks!
  4. Posts : 4,755
    oh, and thanks!
    as seen on the picture, you will need to right click and click assign to
  5. Posts : 8,398
    ultimate 64 sp1
    what i mean is: 6801.bmp = normal button? 6805.bmp = mouseover button? 6809.bmp=clicked?
    please make it clear in the tutorial.
  6. Posts : 4,755
    This should explain it:
    Large Icons:
    Small Icons:
    top: 6809.bmp
    left: 6805.bmp
    right: 6805.bmp
  7. Posts : 8,398
    ultimate 64 sp1
    now i am really confused...
    if i only need 6805.bmp then why do you say replace 6801 and 6809 in the tutorial? the tutorial mentions nothing about large or small icons, nor location of taskbar.
    it is obvious that you know what you are doing, but when you write a tutorial, you have to assume idiots like me are going to read it, so you have to explain more.
    i misunderstood and thought that we had to make three buttons, one for its normal state, one for mouse rollover, and another for when it is clicked. i was wrong...
  8. Posts : 4,755
    That is for the small button, you need to replace the others...But you should do it anyway.
    The picture of the button should be like this:
    First Orb: The start orb itself
    Second Orb: start while mouseover
    Third Orb: Start orb when clicked
    edit: this a png, it will need to be a BMP file, with a black background.
    Attached Thumbnails Attached Thumbnails Start Menu Button - Change-untitled-1-3-.png
  9. Posts : 8,398
    ultimate 64 sp1
    ok, thank you for explaining it to this idiot.
    so 6801.bmp = normal button? 6805.bmp = mouseover button? 6809.bmp=clicked?
    please edit your original tutorial with this extra information.
    and where do i store my new bitmaps? (or will they get saved inside explorer.exe when i assign them?)
    what about transparency? can you assign a png file?
    sorry for the idiot questions, but i want to help you improve your tutorial!
