Hibernate Shortcut - Create
Page 3 of 3 FirstFirst 123
  1. Posts : 72,062
       #20
    You could do the same for them as well. You'll just need to substitute the bottom command for the .bat file below for the one you want instead.
    The message displayed by the echo command can be anything you like to help know what it it's for, etc...
    @echo off
    echo Your message here
    timeout /t 30 /nobreak
    shutdown -h -f
    I'm not sure how to have the abort command work using this method though, but luckily it gives you the option to abort during the prompt.
  2. Posts : 1,364
       #21
    I get a double message display per attached. How to have single? I also don't need to see the path/timeout ...
  3. Posts : 6,330
       #22
    It needs a @echo off as the first statement.
    @echo off
    echo HIBERNATE
    shutdown -h -f
  4. Posts : 1,364
       #23
    Yep! - that's what it needed, thank you DavidE.
    Shawn, thank you for all your help. I think I will keep my 'abort' button around for a while. However, that countdown cmd prompt is really drawing me in.
    oh, and thx to Lordbob75 for this great tutorial,
    -take care all!
  5. Posts : 1,364
       #24
    @echo off
    shutdown -h -f
    I'M BACK - heh, heh,
    I decided to go the .bat file/shortcut route for Restart and Shutdown and I have followed your examples to the letter. HOWEVER - after the command window 30 second countdown is complete it closes and a new window/pop-up appears (attached ) and a new 30 second countdown begins. How do I stop the 2nd pop-up? -thx
    my bat files :
    @echo off
    echo RESTART
    shutdown -r -f
    @echo off
    echo SHUTDOWN
    shutdown -s -f
    Attached Thumbnails Attached Thumbnails Hibernate Shortcut - Create-sd1-1.png
  6. Posts : 72,062
       #25
    You can do that by changing the last command to do the action immediately after the timeout. :)
    @echo off
    echo RESTART
    shutdown -r -f -t 00
    @echo off
    echo SHUTDOWN
    shutdown -s -f -t 00
  7. Posts : 1,364
       #26
    YES! - thx for the fix Shawn, adios ...
  8. Posts : 72,062
       #27
    You're most welcome. :)
