Mouse Pointers - Change
Page 7 of 7 FirstFirst ... 567
  1. Posts : 547
    Windows 7 Enterprise x64
       #60
    to anyone having issues with cursors not being in the C:\Windows\Cursors folder, it also works if you make another folder named Cursors on your PC, in my case I have one on my desktop full of all the cursors I make. it is also much better as you can separate your custom cursors from the windows ones and seves space in the original cursors folder.
  2. Posts : 1,002
    XP Pro (x86) | 7 HP (x86) & (x64) | 7 Pro (x64)
       #61
    Can I create a dedicated folder "3D_Red" for my custom group in C:\Windows\Cursors.
    eg, C:\Windows\Cursors\3D_Red\RedArrow.cur
    When I tried to create the new empty folder, Windows showed an alert/warning with option to continue.
    The cursors I have at hand are all prefixed with "3D_Red" . . . . eg, 3D_Red_Arrow.cur"
    The alert warning is concerning
    If I create a folder (3D_Red) on (say) the desktop, fill it with all "3D_Red" cursors
    ... then copy (move) the "3D_Red" folder to C:|Windowd\Cursors
    Will the sub-folder sabotage themes.
    Q: Or should all cursors be in C:\Windows\Cursors ONLY ?
    Thank you :)
  3. Posts : 72,046
       #62
    Hello Russell,
    To avoid potential issues, I would recommend to keep the cursors you want to use in the "C:\Windows\Cursors" folder.
  4. Posts : 1,002
       #63
    Thank you :)
