How to Create "Internet Options" Shortcuts in Windows
Internet Options contains many settings to allow you to customize your browsing experience in Internet Explorer.
This will show you how to create or download Internet Options shortcuts that can open directly to the General, Security, Privacy, Content, Connections, Programs, and Advanced tabs in Vista, Windows 7, and Windows 8.
EXAMPLE: Internet Options - Internet Properties
NOTE: This is the same page despite the different names that Windows 7 uses for it when opened from the Control Panel vs Internet Explorer.
OPTION ONE
To Download "Internet Options" Shortcuts
1. Do
step 2 to 8 below for what tab(s) you want the Internet Options shortcut(s) to open to.
2. "Internet Properties" Shortcut that Opens to the General Tab
A) Click/tap on the download button below to download the file below, and go to
step 9 below.
Internet_Options_General.zip
3. "Internet Properties" Shortcut that Opens to the Security Tab
step 9 below.
Internet_Options_Security.zip
4. "Internet Properties" Shortcut that Opens to the Privacy Tab
step 9 below.
Internet_Options_Privacy.zip
5. "Internet Properties" Shortcut that Opens to the Content Tab
step 9 below.
Internet_Options_Content.zip
6. "Internet Properties" Shortcut that Opens to the Connections Tab
step 9 below.
Internet_Options_Connections.zip
7. "Internet Properties" Shortcut that Opens to the Programs Tab
step 9 below.
Internet_Options_Programs.zip
8. "Internet Properties" Shortcut that Opens to the Advanced Tab
step 9 below.
Internet_Options_Advanced.zip
9. Save the .zip file to your desktop.
10. Open the .zip file and extract (drag and drop) the Internet Options shortcut to your desktop
11. Unblock the
Internet Options shortcut.
12. In
Vista and
Windows 7, you can now
Pin to Taskbar (Windows 7 only) or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
13. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
14. When done, you can delete the downloaded .zip file if you like.
OPTION TWO
To Manually Create "Internet Options" Shortcuts
1. Right click on or press and hold on an empty area on your desktop, and click/tap on
New and
Shortcut.
2. Copy and paste the command below into the location area for what tab you want the
Internet Options shortcut to open to, and click/tap on the
Next button. (see screenshot below)
- General Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,0
- Security Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,1
- Privacy Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,2
- Content Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,3
- Connections Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,4
- Programs Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,5
- Advanced Tab
- %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL inetcpl.cpl,,6
3. Type
Internet Options for the name, and click/tap on the
Finish button. (see screenshot below)
4. Right click or press and hold on the new
Internet Options shortcut, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab, then click/tap on the
Change Icon button. (see screenshot below)
6. In the line under "Look for icons in this file", copy and past the location below and press
Enter. (see screenshot below)
C:\Windows\System32\inetcpl.cpl
7. Select the icon highlighted in blue above, and click/tap on
OK. (see screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click/tap on
OK. (see screenshot below)
9. In
Vista and
Quick Launch,
10. In
Windows 8, you can
Quick Launch,
