Mouse Pointers - Allow or Prevent Themes to Change
    How to Prevent or Allow Themes to Change Mouse Pointers in Windows 7 and Windows 8
    This will show you how to allow or prevent the mouse pointers from being changed to the mouse pointers included in a new theme instead in Windows 7, Windows 8, and Windows 8.1.
    OPTION ONE
    Allow or Prevent Themes to change Mouse Pointers in Desktop Icon Settings
    1. Open the Control Panel (icons view) in Windows 7 or Windows 8, and click/tap on the Mouse icon.
    2. Close the Control Panel window.
    3. Click/tap on the Pointers tab, and do step 4 or 5 below for what you would like to do. (see screenshot below)
    4. To Allow Themes to Change Mouse Pointers
    A) Check the Allow themes to change mouse pointers box, and go to step 6 below. (see screenshot above)
    5. To Prevent Themes from Changing Mouse Pointers
    A) Uncheck the Allow themes to change mouse pointers box, and go to step 6 below. (see screenshot below step 3)
    6. Click/tap on OK. (see screenshot below step 3)
    OPTION TWO
    Allow or Prevent Themes to change Mouse Pointers using REG File
    The .reg files below are for the registry key and value below.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Themes
    ThemeChangesMousePointers DWORD
    0 = Prevent
    1 = Allow
    1. Do step 2 or 3 below for what you would like to do.
    2. To Allow Themes to Change Mouse Pointers
    A) Click/tap on the Download button below to download the file below, and go to step 4 below.
    Allow_ThemeChangesMousePointers.reg
    Download
    3. To Prevent Themes from Changing Mouse Pointers
    Prevent_ThemeChangesMousePointers.reg
    Download
    4. Save the .reg file to your desktop.
    5. Double click/tap on the downloaded .reg file to Merge it.
    6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.
    7. When finished, you can delete the downloaded .reg file if you like.
  1. Posts : 72,041
    Tutorial updated to add Option Two. :)
  2. Posts : 1
    Windows 8 Ent x64
    I reckon,
    in registry values
    1 will allow & 0 will disallow
  3. Posts : 72,041
    TheTAMAS said:
    I reckon,
    in registry values
    I reckon so.
