Page 22 of 43 FirstFirst ... 12202122232432 ... LastLast
  1. Posts : 72,052
       #210
    Hello Joe,
    The USB key needs to be at least 4 GB in size. :)
  2. Posts : 275
    Win7 Starter 32 bits
       #211
    typed clean all,
    and
    output looks like this?
  3. Posts : 19,383
       #212
    Hi Fluidmotion,
    You first need to select a disk. Try this:
    list disk
    then identify which disk you want to clean, and then type
    select disk #
    then the clean all command
    Regards,
    Golden
    Attached Thumbnails Attached Thumbnails USB Windows 7 Installation Key Drive - Create-capture.jpg
  4. Posts : 168
    Windows 10 Home 64b
       #213
    Can i partition a 15 GB usb flash drive into two partitions so i can transfer one with windows 7 64 bits and in the other with the 32 bits? or is there another way to let me pick one of the version when installing into a hard drive? I already have a usb flash with home premium 64, but i want to have the 32 bits version so i can install it to other machines with valid licenses.
  5. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #214
    Check here, Stage two Windows 7 Universal Installation Disc - Create
    Put them all on one partition on a USB drive, or DVD.
  6. Posts : 74
    Windows 7 64-bit SP1
       #215
    After running through the steps, I get a message saying "NTLDR is missing Press Ctrl+Alt+Del to restart" after the BIOS splash.
  7. Posts : 72,052
       #216
    Hello thebladeroden,
    If you used OPTION TWO with the issues that you are currently having from your other posts, then that may be why it's not working for you.
  8. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
       #217
    Would this work for a USB 2 4GB or will I need to do Method 2.
  9. Posts : 72,052
       #218
    Hello Infinite,
    Sure, if you have or create a ISO file of Windows 7, you could do Option One if you like. :)
  10. Posts : 28
    Windows 7 Home Premium 64 bit
       #219
    Hello, I'm new here.
    I have a laptop that is HP Pavilion dv5, it has Windows 7 Ultimate 32 bits installed on it, I have the 64 bit installation on a USB drive, can I install the 64 bit on my 32 bit system?
    (PS: I have all my important stuff as a backup on my hard drive, and I'm totally ready for a clean installation.)
