Page 25 of 43 FirstFirst ... 15232425262735 ... LastLast
  1. Posts : 72,058
       #240
    USlava77 said:
    Option One - The Windows 7 tool did not work either, after selecting the ISO, it told me that I had an invalid ISO.
    No worries though, as I believe my issue will soon be resolved. I have managed to obtain a different ISO, and with this one, copying to my computer seems to work. I will try the second method again, and get back to you on my results.
    Ok. The first ISO may have been corrupted.
  2. Posts : 4
    The new ISO worked!
    Thanks for your time.
  3. Posts : 72,058
       #242
    That's great news. :)
  4. Posts : 21,004
       #243
    Good to hear US:)
  5. PUP
    WINDOWS 7 HOME PREMIUM 32bit
       #244
    Well,I followed all the directions on how to do this,and it worked!
    Now I'm happy,lol.
  6. Posts : 21,004
       #245
    Hello Brink Just out of curiosity can this method be used for Vista and XP installs as I found the 7 so easy to install this way and have had problems with those OS's using the CD method.
    John
  7. AC
    Windows 7 Home Premium 64-Bit
       #246
    John
    I'm not Brink, but I use UltraISO to make USB's for other OS's.
  8. Posts : 72,058
       #247
    John
    Hello John,
    The method works perfectly in Vista, but don't know about XP. UltraISO works great as well. :)
  9. AC
       #248
    Brink said:
    John
    Hello John,
    My suggestion was called great by a legend
  10. Posts : 21,004
       #249
    Yep our Super hero
    Thanks fellas I'll give it a try as I am having REAL problems with the old girl XP
